The old 'sb' command was deprecated in 2015 and replaced with 'host'. It
is useful to be able to access some internal sandbox state, particularly
for testing.
Resurrect the old command and provide a way to print some basic state
information (currently just the arguments to sandbox).
Remove the remaining users and the command, so that the name is available
for other purposes.
Its only called from this file, so make it static. While at it, remove
some occurances of multiple blank lines as well.
Cc: Boris Brezillon <boris.brezillon@bootlin.com>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
This patch fixes the address information of fdt.
wrong case:
=> fdt addr 0x48000000
=> fdt move 0x48000000 0x41000000 0xa000
=> fdt addr
The address of the fdt is 48000000
Active address in this case is 0x41000000.
Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Add new option to 'adc' command to do a single scan of:
- some channel(s), using mask argument
- all channels available on an ADC device (when optional mask is omitted).
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Use newly introduced adc_raw_to_uV() API to print conversion result
both as raw value and micro-volts by default.
Enhance adc info command to report also the channel mask.
pinmux command allows to :
- list all pin-controllers available on platforms
- select a pin-controller
- display the muxing of all pins of the current pin-controller
or all pin-controllers depending of given options
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
cmd: pinmux: Fix pinmux command
if "pinmux status" command is used without having
set dev using "pinmux dev", print pinmux usage
Display all digits on 64bit systems. Currently we print only the lower
32 bits. Examples of values that can exceed 32 bits are the size and start of
memory banks.
For fdt_blob use the same output method as for other values. This avoids
misalignment.
Add 'virtio' command in U-Boot command line.
part_init() is currently called in every DM BLK driver, either
in its bind() or probe() method. However we can use the BLK
uclass driver's post_probe() method to do it automatically.
Update all DM BLK drivers to adopt this change.
Commit c58fb2cdb3e4 ("cmd: ubi: clean the partition handling")
introduced a call to mtd_probe_devices() in the ubi_attach() path
and this function takes care of parsing mtdparts/mtdids and
creating/registering the associated mtd partitions.
The mtdparts_init() call in the ubi_detach() path is not only
unnecessary but can sometimes print error messages even when things
work properly (that's the case with SPI NAND devices that have not
been probed with 'mtd list'), which is misleading.
Remove this call to mtdparts_init() and drop the dependency on
CMD_MTDPARTS.
Fixes: c58fb2cdb3e4 ("cmd: ubi: clean the partition handling")
Reported-by: Stefan Roese <sr@denx.de>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Tested-by: Stefan Roese <sr@denx.de>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
gwventana configs are relying on CMD_UBI to select CMD_MTDPARTS,
which is then making {MTDIDS,MTDPARTS}_DEFAULT options available.
We are about to remove the 'select CMD_MTDPARTS' statement in the
CMD_UBI entry, but if we do that without first making sure
{MTDIDS,MTDPARTS}_DEFAULT are visible, we end up with a build
failure when building gwventana configs.
Address that by adding a depends on MTD_PARTITIONS to
{MTDIDS,MTDPARTS}_DEFAULT which does the trick since CMD_UBI selects
MTD_UBI which in turn selects MTD_PARTITIONS.
We also get rid of the depends on CMD_MTD, since CMD_MTD also selects
MTD_PARTITIONS.
Reported-by: Jagan Teki <jagan@amarulasolutions.com>
This line is no more needed and can be removed.
Only CONFIG_CMD_SOURCE is defined in Kconfig and
used in defconfig files.
CONFIG_SOURCE if not defined in source code and
"config SOURCE" is not present in any Kconfig.
Currently the base is 3 fix it 10 so that IDs follow decimal system.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvulta@ti.com>
All mii operations require a valid PHY address except the 'device'
command, which expects the PHY name rather than the address.
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
Patch queue for efi - 2018-10-17
A few bug fixes for the 2018.11 release:
- Fix block seeking on 32bit
- Fix execution with DEBUG set
- Fix a few Coverity found bugs
- Fix warnings
Heinrich Schuchardt (13):
efi_loader: fix relocation on x86_64
efi_loader: correct signature of GetPosition, SetPosition
efi_loader: execute efi_save_gd() first
efi_loader: efi_allocate_pool(EFI_ALLOCATE_ANY_PAGES, ...)
efi_loader: error handling in read_console()
efi_loader: return type efi_console_register()
efi_loader: superfluous statement in is_dir()
efi_loader: memory leak in efi_set_variable()
efi_loader: remove lcd.h from efi_net.c
arm: do not include efi_loader.h twice
efi_loader: fix typo in efi_boottime.c
efi_selftest: creating new handle in controller test
efi_loader: efi_dp_get_next_instance() superfluous statement
Tom Rini (2):
efi_loader: Fix warning in efi_load_image()
fs: fat: Fix warning in normalize_longname()
Only PPC supports this option that's why there should be proper
dependency setup via Kconfig.
If DEBUG is defined we may be calling EFI_CALL already during the
initialization of the EFI subsystem. We must make sure efi_save_gd() has
already been called at that moment.
Anyway it is better to have this call in one location instead of three.
This fixes an illegal memory access occurring since 4e6b5d6503ce
("efi_loader: create root node") with DEBUG = 1.
Fixes: 4e6b5d6503ce ("efi_loader: create root node")
Test improvements to tidy up output and drop duplicate tests
Sandbox SPL/TPL support
Various dm-related improvements
When updating the board FDT, some of the operations
are performed by ft_board_setup_ex() and should be
executed also by the fdt command.
Signed-off-by: Nicholas Faustini <nicholas.faustini@azcomtech.com>
Allow selection of which EC image to hash.
At present the mtrr functions disable the cache before making changes and
enable it again afterwards. This is fine in U-Boot, but does not work if
running in CAR (such as we are in SPL).
Update the functions so that the caller can request that caches be left
alone.
This file has changed quite a bit in the last 5 years as the capabilities
of the ECs have grown. Sync it up with the copy in coreboot commit
b9141f2215.
The only change is the addition of EC_VBNV_BLOCK_SIZE_V2. This is needed
because U-Boot uses the new v2 vboot API and this is not currently fully
supported by Chromium OS firmware.
These are needed for the 2018 version of Chromium OS vboot. Add an
implementation for TPM v1, with v2 to come later.
At present we pass around a private pointer to specify the cros_ec device.
With driver model it makes more sense to pass the device. Update the code
to do this.
Add a way in configuration files (exlinux.conf for sysboot command)
to select a specific FIT configuration. The configuration is selected
with a string added after the FIT filename in the label "KERNEL" or
"LINUX", using the same format than bootm command:
KERNEL [Filename]#<conf>[#<extra-conf[#...]]
This configuration string, beginning by '#', is directly appended
to bootm argument 1 after <kernel_addr_r>.
bootm [<kernel_addr_r>]#<conf>[#<extra-conf[#...]]
see doc/uImage.FIT/command_syntax_extensions.txt for details
Example :
KERNEL /fit.itb#cfg1
KERNEL /fit.itb#cfg2
Configuration can be use also for overlay management :
KERNEL /fit.itb#cfg1#dtbo1#dtbo3
see doc/uImage.FIT/overlay-fdt-boot.txt for details
Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
Prior to this patch was do_avb_write_rb() reading supplied rb_idx as a
hexadecimal number while do_avb_read_rb() printed the read out rb_idx as
decimal number. For consistency change do_avb_read_rb() to print rb_idx
as a hexadecimal number too.
Reviewed-by: Igor Opaniuk <igor.opaniuk@linaro.org>
Add printing of U-Boot relocation address.
Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Since the mach_id is not used by RISC-V, remove it.
This is the PR for SPI-NAND changes along with few spi changes.
[trini: Re-sync changes for ls1012afrwy_qspi*_defconfig]
The 'mtdparts' command is not needed anymore. While the environment
variable is still valid (and useful, along with the 'mtdids' one), the
command has been replaced by 'mtd' which is much more close to the MTD
stack and do not add its own specific glue.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
UBI should not mess with MTD partitions, now that the partitions are
handled in a clean way, clean the ubi command and avoid using this
uneeded extra-glue to reference the devices.
There should not be a 'nand' command, a 'sf' command and certainly not
a new 'spi-nand' command. Write a 'mtd' command instead to manage all
MTD devices/partitions at once. This should be the preferred way to
access any MTD device.
Acked-by: Jagan Teki <jagan@openedev.com>
Prevent cache warning messages when using the 'bootelf' command on an
Arm target. Round down each section start address and round up the
respective section end to the nearest cache line.
Signed-off-by: Neil Stainton <nstainton@asl-control.co.uk>
[trini: Manually apply, rework whitespace]
Fix failure to reimport exported checksummed, size constrained data block.
'env export -c' command ignores optional -s size argument when calculating checksum causing subsequent 'env import -c' to fail.
Add trivial implementation of the clk dump in case DM is enabled.
This implementation just iterates over all the clock registered
with the CLK uclass and prints their rate.
Cc: Chin Liang See <chin.liang.see@intel.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Previously poweroff was located under boot. It seems to make more
sense to have it located under the Device access commands.
Add basic command for bus information and read for onewire
bus using Dallas 1-Wire protocol.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
cmd_ubifs_mount() function would be called directly instead of
involving whole command machinery for mounting ubifs in
generic firmware loader, so some checking codes need to be factored out
into cmd_ubifs_mount() without breaking original functionality design.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
cmd_ubifs_umount() function would be called directly instead of involving
whole command machinery in generic firmware loader, so checking on
ubifs_initialized status need to be done in cmd_ubifs_umount() without
[trini: Fix conflicting type error in cmd/ubi.c]
Add command to query information from and write text to on-screen
display (OSD) devices.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Patch queue for efi - 2018-09-26
A lot of goodness in this release. We're *very* close to running the
UEFI Shell and SCT natively. The only missing piece are HII protocols.
- FAT write support (needed for SCT)
- improved FAT directory support (needed for SCT)
- RTC support with QEMU -M virt
- Sandbox support (run UEFI binaries in Linux - yay)
- Proper UTF-16 support
- EFI_UNICODE_COLLATION_PROTOCOL support (for UEFI Shell)
- EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL support (for UEFI Shell)
- Fix window size determination
- Fix Tegra by explicitly unmapping RAM
- Clean up handle entanglement
- Lots of generic code cleanup
[trini: Fixup merge conflict in include/configs/qemu-arm.h]
The 'conitrace' command prints the codes received from the console input as
hexadecimal numbers.
This developer utility is useful for testing the handling of special keys
by keyboard drivers.
Create the handle of loaded images and the EFI_LOADED_IMAGE_PROTOCOL
inside efi_setup_loaded_image(). Do not use local variables.
Currently we expect the loaded image handle to point to the loaded image
protocol. Additionally we have appended private fields to the protocol.
With the patch the handle points to a loaded image object and the private
fields are added here. This matches how we handle the net and the gop
object.
When running in EL3 mode on AArch64, we have to first drop to EL2
to execute a UEFI payload. When dropping down, the arguments to
the entry point have to stay identical to the ones for normal entry
though.
In commit ea54ad59286 ("efi_loader: pass handle of loaded image")
we incorrectly changed that logic and had the el3 entry path diverge.
Fix it up by syncing it back to what it's supposed to be.
Fixes: ea54ad59286 ("efi_loader: pass handle of loaded image")
Reviewed-by: Mark Kettenis <kettenis@openbsd.org>
Currently we assign a lot of protocols to loaded images though
these protocols are not related to them. Instead they should be
installed on a separate handle. Via the device path it is the
parent to the devices like the network adapter.
