Move this function to the new header file and rename it so it has an env_
prefix.
This function fits better with the network subsystem, so move it.
Suggested-by: Joe Hershberger <joe.hershberger@ni.com>
Move env_get() over to the new header file.
Move env_set() over to the new header file.
Move env_get_hex() over to the new header file.
Move env_get_yesno() over to the new header file.
Move env_set_ulong() over to the new header file.
Move env_set_hex() over to the new header file along with env_set_addr()
which uses it.
Move envmatch() over to the new header file. Also rename it to env_match()
to better line up with other functions.
Move this function over to the new header file.
Move this function over to the new header file. Also rename it to have an
env_ prefix like the other functions.
As part of the effort to remove things from common.h, create a new header
for the gzip functions. Move the function declarations to it and add
missing documentation.
- DaVinci USB updates
- Various OHCI fixes
- Gadget fixes
FSP (CONFIG_HAVE_FSP) and Slim Bootloader (CONFIG_SYS_SLIMBOOTLOADER)
consume HOB (CONFIG_USE_HOB) data from the each HOB list pointer.
Add a common HOB library in lib/hob.c and include/asm/hob.h.
Signed-off-by: Aiden Park <aiden.park@intel.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Use existing EFI_GUID and efi_guid_t instead of struct efi_guid.
This is pre-work before making a common HOB library.
- Change 'struct efi_guid' to efi_guit_t
- Remove 'struct efi_guid'
- Define GUIDs with EFI_GUID() macro
- Use guidcmp() instead of compare_guid()
- Remove compare_guid()
Tested on MinnowMax
Registration of USB download gadget might fail for various reasons, so
add a check for g_dnl_register() funtion return value. Without this fix,
thor_init() will try to access the registered gadget structures resulting
in NULL pointer dereference issue.
When building U-Boot with AVB enabled, compiler shows next warnings:
cmd/avb.c: In function 'do_avb_read_pvalue':
cmd/avb.c:371:18: warning: format '%ld' expects argument of type
'long int', but argument 2 has type 'size_t'
{aka 'unsigned int'} [-Wformat=]
printf("Read %ld bytes, value = %s\n", bytes_read,
%d
cmd/avb.c: In function 'do_avb_write_pvalue':
cmd/avb.c:404:19: warning: format '%ld' expects argument of type
'long int', but argument 2 has type '__kernel_size_t'
printf("Wrote %ld bytes\n", strlen(value) + 1);
%d
Fix those by using "%zu" specified.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Igor Opaniuk <igor.opaniuk@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for v2019.10-rc2
With this pull request a workaround for GRUB on 32bit ARM is re-enabled
and made customizable. Without the patch booting on ARM 32bit with GRUB
prior to version 2.04 or with a cache which is not managed via CP15
fails.
Further work will be needed to achieve a UEFI compliant cache handling.
According to the UEFI spec all caches except those that cannot be
managed via CP15 should be enabled.
An implementation of the ConvertPointer() runtime service is provided.
efi_crt0 is always rebuild to avoid having to call 'make mrproper' when
switching architectures.
CONFIG_AUTOBOOT_MENU_SHOW
Rename this option to CONFIG_AUTOBOOT_MENU_SHOW this it relates to the
autoboot functionality.
Since this is part of the autoboot functionality, it makes sense to name
it with an AUTOBOOT prefix. No mainline boards use it so this should be
safe, and downstream boards will need to adjust.
Since this option is just an integer value, it really needs another option
to control whether the feature is enabled or not. Add a new
CONFIG_USE_AUTOBOOT_MENUKEY for that. This fits better with how things are
done with Kconfig, avoiding the need to use a specific value to disable
the feature.
This option is not documented properly at present. Fix it.
https://gitlab.denx.de/u-boot/custodians/u-boot-video
- fix EDID mode filtering
- extend mxc_ipuv3_fb to enable backlight/display
- include fb_base in global_data for DM_VIDEO
- show frame buffer address via board info
as used to be with legacy VIDEO support
make htmldocs produces a warning:
./cmd/efidebug.c:733: WARNING: Unexpected indentation.
Correct the indentation.
Remove 'See above for details of sub-commands.' which is not helpful in the
Sphinx generated documentation.
show Framebuffer base with CONFIG_DM_VIDEO
enabled.
A couple minor tweaks to printed strings in cmd/fpga.c.
off/on/flush are currently silently ignored.
Signed-off-by: Eric Perie <eric.perie@yahoo.com>
Linker generated array entry is not needed when the command line is
disabled. Remove this code in that case.
This is required as the commit 80a48dd47e3bf3ede676fae5a630cb6c80de3e69
breaks the linking stage when CONFIG_CMDLINE=n:
LDS u-boot.lds
LD u-boot
u-boot contains unexpected relocations: R_ARM_NONE
R_ARM_RELATIVE
make: *** [Makefile:1775: checkarmreloc] Error 1
Signed-off-by: Andrej Rosano <andrej.rosano@f-secure.com>
- Bring in the rest of the J271E platform
- Various OMAP3/AM3517, DA850 fixes
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20190719
- CCF for i.MX6
- nandbcb command to write SPL into NAND
- Switch to DM (i.MX28)
- Boards: Toradex, engicam, DH
- Fixes for i.MX8
- Fixes for i.MX7ULP
Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/561147504
'rproc list' is currently allowed only after probing all the
available remoteproc devices. Given that 'rproc init' is updated
to probe and initialize devices individually, allow the 'rproc list'
command to print all probed devices at any point.
'rproc init' does the probe and initialization of all the available
remoteproc devices in the system. This doesn't allow the flexibility
to initialize the remote cores needed as per use case. In order
to provide flexibility, update 'rproc init' command to accept one
more parameter with rproc id which when passed initializes only
that specific core. If no id is passed, command will initializes
all the cores which is compatible with the existing behaviour.
For A/B system update support the Android boot process requires to send
'androidboot.slot_suffix' parameter as a command line argument. This
patch implementes 'ab_select' command which allows us to obtain current
slot by processing the A/B metadata.
The patch was extracted from commit [1] with one modification: the
separator for specifying the name of metadata partition was changed
from ';' to '#', because ';' is used for commands separation.
[1] https://android-review.googlesource.com/c/platform/external/u-boot/+/729880/2
Signed-off-by: Ruslan Trofymenko <ruslan.trofymenko@linaro.org>
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
Reviewed-by: Alistair Strachan <astrachan@google.com>
Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
These have been reported by Simon in [1] and fixed in [2].
However, since [1] has already been pushed to u-boot/master, the
improvements incorporated in [2] are now extracted and resubmitted.
The changes are in the area of coding style and best practices:
* s/field/fieldp/, s/size/sizep/, to convey that the variables return
an output to the caller
* s/err_1/err_read_fail/, s/err_2/err_too_small/, to be more descriptive
* Made sure 'static int do_bcb_load' appears on the same line
* Placed a `/*` on top of multi-line comment
[1] https://patchwork.ozlabs.org/patch/1104244/#2200259
[2] https://patchwork.ozlabs.org/cover/1128661/
("[v4,0/4] Add 'bcb' command to read/modify/write Android BCB")
Fixes: db7b7a05b267 ("cmd: Add 'bcb' command to read/modify/write BCB fields")
Reported-by: Simon Glass <sjg@chromium.org>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Quote from https://patchwork.ozlabs.org/patch/1104244/#2210814:
----------8<-----------
strncmp() is chosen for the sake of paranoid/defensive programming.
Indeed, strncmp() is not really needed when comparing a variable
with a string literal. We expect strcmp() to behave safely even if the
string variable is not NUL-terminated.
In the same scenario, Linux v5.2-rc7 uses both strcmp() and strncmp(),
but the frequency of strcmp() is higher:
$ git --version
git version 2.22.0
$ (Linux 5.2-rc7) git grep -En 'strncmp\([^"]*"[[:alnum:]]+"' | wc -l
1066
$ (Linux 5.2-rc7) git grep -En 'strcmp\([^"]*"[[:alnum:]]+"' | wc -l
1968
A quick "strcmp vs strncmp" object size test shows that strcmp()
generates smaller memory footprint (gcc-8, x86_64):
$ (U-Boot) size cmd/bcb-strncmp.o cmd/bcb-strcmp.o
3373 400 2048 5821 16bd cmd/bcb-strncmp.o
3314 400 2048 5762 1682 cmd/bcb-strcmp.o
So, overall, I agree to use strcmp() whenever variables are compared
with string literals.
Fix warning V1037 reported by PVS-Studio Static Analyzer:
Two or more case-branches perform the same actions. Check lines: 49, 53
Commit 9bdf0e8fef86 ("doc: relocate/rename Android README and add BCB
overview") left some obsolete references of Android documents/paths.
This has been pointed out by Sam (thanks!) in:
https://patchwork.ozlabs.org/patch/1104245/#2208134
Fixes: 9bdf0e8fef86 ("doc: relocate/rename Android README and add BCB overview")
Reported-by: Sam Protsenko <semen.protsenko@linaro.org>
Suggested-by: Sam Protsenko <semen.protsenko@linaro.org>
This sub-command serves for getting the partition index from
partition name. Also it can be used to test the existence of specified
partition.
Use case:
For example, in most CI environments this U-Boot command for automatic
testing of Linux rootfs is used:
=> setenv bootpart 1:f
where 0xf is "userdata" partition. But the number of "userdata"
partition can be changed any time, when partition table is changed.
So it would be nice to get rid of that 0xf magic number and use
partition name instead, like this:
=> part number mmc 1 userdata part_num
=> setenv bootpart 1:${part_num}
Pull request for UEFI sub-system for v2019.10-rc1 (2)
* Implement the EVT_SIGNAL_VIRTUAL_ADDRESS_CHANGE event.
* Address errors of type -Werror=address-of-packed-member when building
with GCC9.1
* Fix an error when adding memory add addres 0x00000000.
* Rework some code comments for Sphinx compliance.
This commit just corrects spelling of 'accessed' word in the EEPROM
comment.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
This option will provide the offset in the parallel NOR flash memory to,
which the falcon boot data is stored.
The CMD_SPL_NAND_OFS description was a bit misleading, has
been updated.
This commit makes the CMD_SPL_NAND_OFS only visible when we use NAND
memory.
Before this change it was present when only CMD_SPL was enabled (and
would stay when board with other falcon boot medium is used).
Calling 'mdio read ...' currently leads to a data abort when no mdio
bus is found.
To fix this, check if 'bus' is a valid pointer before accessing it.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Vladimir Oltean <olteanv@gmail.com>
Reviewed-by: Vladimir Oltean <olteanv@gmail.com>
This command fills the memory with data produced by rand().
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
this patch adds basic changes for adding a erase-subcommand to env
with this command the environment stored on non-volatile storage written
by saveenv can be cleared.
Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
squashed fixes
- start message with "Erasing"
- mark erase-function as optional
- env: separate eraseenv from saveenv
Suggested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Adjust comments for Sphinx.
Describe efi_set_bootdev().
Change function descriptions to Sphinx style.
We currently have some inconsistent use of efi_add_memory_map()
throughout the code. In particular the return value of efi_add_memory_map()
is not interpreted the same way by various users in the codebase.
This patch does the following:
- Changes efi_add_memory_map() to return efi_status_t.
- Adds a method description to efi_add_memory_map().
- Changes efi_add_memory_map() to return EFI_SUCCESS
- Returns non-zero for error in efi_add_memory_map()
- Updates efi_allocate_pages() to new efi_add_memory_map()
- Updates efi_free_pages() to new efi_add_memory_map()
- Updates efi_carve_out_dt_rsv() to new efi_add_memory_map()
- Updates efi_add_runtime_mmio() to new efi_add_memory_map()
Fixes: 5d00995c361c ("efi_loader: Implement memory allocation and map")
Fixes: 74c16acce30b ("efi_loader: Don't allocate from memory holes")
Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Cc: Alexander Graf <agraf@csgraf.de>
Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
