path: root/cmd/ximg.c
2018-04-06cmd: ximg: Respect cache line size for flushingMario Six
Make sure that the cache line size if respected when flushing the cache. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
