path: root/cmd/x86
2019-04-22cmd: add exception commandHeinrich Schuchardt
The 'exception' command allows to test exception handling. This implementation supports ARM, x86, RISC-V and the following exceptions: * 'breakpoint' - prefetch abort exception (ARM 32bit only) * 'unaligned' - data abort exception (ARM only) * 'undefined' - undefined instruction exception Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-10-09x86: Update mtrr functions to allow leaving cache aloneSimon Glass
At present the mtrr functions disable the cache before making changes and enable it again afterwards. This is fine in U-Boot, but does not work if running in CAR (such as we are in SPL). Update the functions so that the caller can request that caches be left alone. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-08x86: Move commands from under arch/x86 to cmd/x86/Tom Rini
We only need to compile and link these files when building for full U-Boot. Move them to under cmd/x86/ to make sure they aren't linked in and undiscarded due to u_boot_list_2_cmd_* being included). Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
