Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Some HOBs include information that can be decoded. Add a -v option to the
hob command, to allow this to be displayed. Add the ability to decode a
resource descriptor.
GUIDs are one of the seven evils of the computer world. They obfuscate the
meaning and require people to look up long hex strings to decode it.
Luckily only a miniscule fraction of the 10^38 possible GUIDs are in use.
Add a way to decode the GUIDs known to U-Boot. Add a few more to the list
for good measure.
The 'hob' command currently lists all HOB entries. Add way to list a
single entry, by index.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this uncommon header out of the common header.
FSP (CONFIG_HAVE_FSP) and Slim Bootloader (CONFIG_SYS_SLIMBOOTLOADER)
consume HOB (CONFIG_USE_HOB) data from the each HOB list pointer.
Add a common HOB library in lib/hob.c and include/asm/hob.h.
Signed-off-by: Aiden Park <aiden.park@intel.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
