path: root/cmd/usb_mass_storage.c
2016-07-27dm: usb: Use blk_dread/write() instead of direct callsSimon Glass
Update the USB mass storage code to allow it to work with driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-20cmd/usb_mass_storage.c: Rework ums_init() ret logic slightlyTom Rini
Previously, ret could be used uninitialized if blk_get_device_part_str() failed. Default to ret being set to -1 so that we always return an err up if we have a problem and then invert the logic on testing ums_count as when that is non-zero is the time we can return 0. Cc: John Tobias <john.tobias.ph@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: ums - expose selected partition/sJohn Tobias
By applying this patch, it will give us some flexibility to expose a selected partition/s. e.g: 1. To expose several partitions ums 0 mmc 0:1,0:6 2. To expose the all partitions ums 0 mmc 0:0 3. To expose multiple partititions on several devices ums 0 mmc 0:1,1:6 4. It support legacy format ums 0 mmc 0 Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
2016-03-14dm: block: Rename device number member dev to devnumSimon Glass
This is a device number, and we want to use 'dev' to mean a driver model device. Rename the member. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device() to blk_get_device_by_str()Simon Glass
The current name is too generic. The function returns a block device based on a provided string. Rename it to aid searching and make its purpose clearer. Also add a few comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
