path: root/cmd/usb.c
2017-11-26cmd: usb: ignore blk, emulation devices in usb tree/info displaySuneel Garapati
Usb tree/info commands iterate over all usb uclass devices recursively. Blk uclass devices based on struct blk_desc are created for mass storage device, treating them as usb uclass devices based on struct usb_device and referencing usb config interface descriptors cause crash. To fix, ignore blk and usb_emul uclass devices in usb_show_info and usb_tree_graph. Also avoid addition of preamble for blk uclass child devices, otherwise tree dump gets messed up. Signed-off-by: Suneel Garapati <suneelglinux@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-17dm: usb: Adjust the 'usb' command to use blk_common_cmd()Simon Glass
Instead of having separate code in the 'usb' command, adjust it to use the common function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-28usb: cmd: Print actual packet size for super speed devicesBin Meng
USB 3.0 defines bMaxPacketSize0 field in the device descriptor as the exponent of 2, so let's print the calculated actual size. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-01-17usb: storage: Show number of storage devices detected for DM_USBMichal Simek
By enabling DM_USB information about number of storage devices was lost. Get this information back simply by printing number of devices detected via BLK uclass. For example: scanning bus 0 for devices... 7 USB Device(s) found scanning usb for storage devices... 3 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-07-05usb: dm: Make "usb info" use usb_for_each_root_dev()Hans de Goede
The old dm "usb info" implementation has several issues: 1) NULL pointer deref when a bus has no children 2) Not showing usb devices on busses without an emulated root-hub (otg host) 3) Attempting to show devices on inactive busses 4) "usb info" Would cause some hosts to get re-probed something which only "usb reset" should do TL;DR: proper iterating over usb bus root devs is hard, use the helper for it. Reported-by: Bernhard Nortmann <bernhard.nortmann@web.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-07-05usb: dm: Add a usb_for_each_root_dev() helper functionHans de Goede
Iterating over usb-root devs and doing something for all of them is a bit tricky with dm, factor out the proven usb_show_tree() for this into a helper function. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-18cmd: usb: check if_type before using this devicePeng Fan
For legacy usb storage driver, USB_MAX_STOR_DEV is defined as 7. If we only have one usb disk on board, `usb dev 0` is ok. But if `usb dev 1`, still ok, then `usb read xxx` will trigger system fault and reboot. So check if_type before using this device. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Simon Glass <sjg@chromium.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stephen Warren <swarren@nvidia.com>
2016-05-17dm: usb: Drop the get_dev() functionSimon Glass
This function is implemented by the legacy block functions now. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-10dm: usb: Do not reprobe usb hosts on "usb tree" commandHans de Goede
Some usb hosts may have failed to probe on "usb start", i.e. an otg host without an otg-host cable plugged in. "usb tree" would cause the probe method of these hosts to get called again, something which should only happen on "usb reset". This commit fixes this. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-10usb: kbd: Do not deregister usbkbd twice when using dmHans de Goede
The dm usb_kbd_remove function() will deregister the usb keyboard for us on a "usb reset" / "usb stop" so there is no need to manually call usb_kbd_deregister() in the dm case. This commit removes usb_kbd_deregister() in the dm case fixing the following "usb reset" errors: usb_kbd_remove: warning, ret=-6 device_remove: Device 'usb_kbd' failed to remove, but children are gone Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-14dm: block: Adjust device calls to go through helpers functionSimon Glass
To ease conversion to driver model, add helper functions which deal with calling each block device method. With driver model we can reimplement these functions with the same arguments. Use inline functions to avoid increasing code size on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
