path: root/cmd/tpm_test.c
2018-11-29tpm: Convert to use a device parameterSimon Glass
At present many TPM calls assume there is only one TPM in the system and look up this TPM themselves. This is inconsistent with driver model, which expects all driver methods to have a device parameter. Update the code to correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09tpm: Add a few new commands for v1Simon Glass
These are needed for the 2018 version of Chromium OS vboot. Add an implementation for TPM v1, with v2 to come later. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: disociate TPMv1.x specific and generic codeMiquel Raynal
There are no changes in this commit but a new organization of the code as follow. * cmd/ directory: > move existing code from cmd/tpm.c in cmd/tpm-common.c > move specific code in cmd/tpm-v1.c > create a specific header file with generic definitions for commands only called cmd/tpm-user-utils.h * lib/ directory: > move existing code from lib/tpm.c in lib/tpm-common.c > move specific code in lib/tpm-v1.c > create a specific header file with generic definitions for the library itself called lib/tpm-utils.h * include/ directory: > move existing code from include/tpm.h in include/tpm-common.h > move specific code in include/tpm-v1.h Code designated as 'common' is compiled if TPM are used. Code designated as 'specific' is compiled only if the right specification has been selected. All files include tpm-common.h. Files in cmd/ include tpm-user-utils.h. Files in lib/ include tpm-utils.h. Depending on the specification, files may include either (not both) tpm-v1.h or tpm-v2.h. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Fix a few more cases of tpm.h -> tpm-v1.h, some Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02cmd/tpm_test: Fix misleading code indentationStefan Brüns
GCC 6.2 reasonably complains about the current code: ../cmd/tpm_test.c: In function ‘do_tpmtest’: ../cmd/tpm_test.c:540:3: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation] for (i = 0; i < argc; i++) ^~~ ../cmd/tpm_test.c:542:4: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the ‘for’ printf("\n------\n"); ^~~~~~ Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Reviewed-by: Simon Glass <sjg@chromium.org> Updated to remove C99 variable decl: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
