path: root/cmd/thordown.c
2019-03-08cmd: thordown: Fix spelling of download.Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-12-07usb: gadget: Do not call board_usb_xxx() directly in USB gadget driversJean-Jacques Hiblot
Add 2 functions to wrap the calls to board_usb_init() and board_usb_cleanup(). This is a preparatory work for DM support for UDC drivers (DM_USB_GADGET). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-06-07cmd: add missing line breaks for pr_err()Seung-Woo Kim
After the commit 9b643e312d52 ("treewide: replace with error() with pr_err()"), there are some pr_err() with no line break. Add missing line breaks. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
