path: root/cmd/spi.c
2020-06-29spi: Convert CONFIG_DM_SPI* to CONFIG_$(SPL_TPL_)DM_SPI*Lukasz Majewski
This change allows more fine tuning of driver model based SPI support in SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI support in SPL and TPL via Kconfig option. Before this change it was necessary to use: /* SPI Flash Configs */ #if defined(CONFIG_SPL_BUILD) #undef CONFIG_DM_SPI #undef CONFIG_DM_SPI_FLASH #undef CONFIG_SPI_FLASH_MTD #endif in the ./include/configs/<board>.h, which is error prone and shall be avoided when we strive to switch to Kconfig. The goal of this patch: Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL). Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must still support non DM driver. Another use case is the conversion of non DM/DTS SPI driver to support DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the distinction is needed in Kconfig (also if SPL version of the driver supports OF_PLATDATA). In the end of the day one would have to support following use cases (in single driver file - e.g. mxs_spi.c): - U-Boot proper driver supporting DT/DTS - U-Boot proper driver without DT/DTS support (deprecated) - SPL driver without DT/DTS support - SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to run full blown DT/DTS) - SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained environment with no fitImage and OF_LIBFDT support). Some boards do require SPI support (with DM) in SPL (TPL) and some only have DM_SPI{_FLASH} defined to allow compiling SPL. This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI) and provides corresponding defines in Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [trini: Fixup a few platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-27cmd: spi: Permit setting bus frequencyMarek Vasut
The 'sspi' command hard-coded 1 MHz bus frequency for all transmissions. Allow changing that at runtime by specifying '@freq' bus frequency in Hz. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-03-25Convert CONFIG_DEFAULT_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_DEFAULT_SPI_BUS CONFIG_DEFAULT_SPI_MODE Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2016-03-27cmd: spi: check return value of strdupPeng Fan
Check return value of strdup. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
