Call blk_dread, blk_dwrite, blk_derase to ensure that the block cache is
used if enabled and to remove build breakage when CONFIG_BLK is enabled.
Signed-off-by: Eric Nelson <eric@nelint.com>
This is a device number, and we want to use 'dev' to mean a driver model
device. Rename the member.
Rename three partition functions so that they start with part_. This makes
it clear what they relate to.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
