When sata stop is executed, the sata_curr_device is not reset to -1, so
any following sata commands will not initialize the sata again and cause
problem.
Additional, in sata init implementation, the sata_curr_device should be updated,
otherwise sata will be initialized again when doing other sata commands like
read/write/info/part/device.
Signed-off-by: Ye Li <ye.li@nxp.com>
Update this command to support driver model. This has a different way of
starting and stopping SATA.
Instead of having separate code in the 'sata' command, adjust it to use
the common function.
Since commit aa6ab905b2, sata_initialize returns -1 if init_sata or
scan_sata fails. But this return value becomes the do_sata return
value which is equivalent to CMD_RET_USAGE.
In case one issues 'sata init' and that the hardware fails to
initialize, there's no need to display the command usage. Instead
the command shoud just return the CMD_RET_FAILURE value.
Fixes: aa6ab905b2 (sata: fix sata command can not being executed bug)
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
Reviewed-by: Eric Nelson <eric@nelint.com>
Commit d97dc8a0 separated the non-command code into its own file
which caused variable sata_curr_device can not be set to a correct
value.
Before commit d97dc8a0, variable sata_curr_device can be set
correctly in sata_initialize().
After commit d97dc8a0, sata_initialize() is moved out to its own file.
Accordingly, variable sata_curr_device is removed from sata_initialize()
too. This caused sata_curr_device never gets a chance to be set properly
which prevent other commands from being executed.
This patch sets variable sata_curr_device properly.
Fixes: d97dc8a0 (dm: sata: Separate the non-command code into its
own file)
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
At present the SATA command code includes both the command-processing code
and the core SATA functions and data structures.
Separate the latter into its own file, adding functions as needed to avoid
the command code accessing data structures directly.
With this commit:
- All CONFIG option are referenced from the non-command code
- The concept of a 'current SATA device' is confined to the command code
This will make it easier to convert this code to driver model.
This file has a few coding style problems. Fix these to make future updates
easier.
Call blk_dread, blk_dwrite, blk_derase to ensure that the block cache is
used if enabled and to remove build breakage when CONFIG_BLK is enabled.
Signed-off-by: Eric Nelson <eric@nelint.com>
This is a device number, and we want to use 'dev' to mean a driver model
device. Rename the member.
Rename three partition functions so that they start with part_. This makes
it clear what they relate to.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
