path: root/cmd/reginfo.c
2017-07-22powerpc: Remove unneccessary #ifdefs in reginfoChristophe Leroy
reginfo command is calling mpc8xx_reginfo(), mpc85xx_reginfo() or mpc86xx_reginfo() based on CONFIG_ symbol. As those 3 functions can't me defined at the same time, let's rename them print_reginfo() to avoid the #ifdefs The name is kept generic as it is not at all dependent on powerpc arch and any other arch could want to also print such information. In addition, as the Makefile compiles cmd/reginfo.c only when CONFIG_CMD_REGINFO is set, there is no need to enclose the U_BOOT_CMD definition inside a #ifdef CONFIG_CMD_REGINFO Lets all remove the #ifdefs around the U_BOOT_CMD as this file is only compiled when CONFIG_CMD_REGINFO is defined Finally, this is a PowerPC-only command, disable it on a number of non-PowerPC platforms. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-08powerpc, 8xx: move specific reginfoChristophe Leroy
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 5xx: remove support for 5xxHeiko Schocher
There was for long time no activity in the 5xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 5xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
