path: root/cmd/qfw.c
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-23cmd: qfw: do not require default macros when building qfw commandMiao Yan
The qfw command interface makes use of CONFIG_LOADADDR and CONFIG_RAMDISKADDR to setup kernel. But not all boards have these macros, which causes build problem on those platforms. This patch fixes this issue. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23cmd: qfw: rename qemu_fw_cfg.[c|h] to qfw.[c|h]Miao Yan
Make file names consistent with CONFIG_QFW and CONFIG_CMD_QFW Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: split qfw command interface and qfw coreMiao Yan
This patch splits qfw command interface and qfw core function into two files, and introduces a new Kconfig option (CONFIG_QFW) for qfw core. Now when qfw command interface is enabled, it will automatically select qfw core. This patch also makes the ACPI table generation select CONFIG_QFW. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
