path: root/cmd/pinmux.c
2018-11-16cmd: pinmux: Add pinmux commandPatrice Chotard
pinmux command allows to : - list all pin-controllers available on platforms - select a pin-controller - display the muxing of all pins of the current pin-controller or all pin-controllers depending of given options Signed-off-by: Patrice Chotard <patrice.chotard@st.com> cmd: pinmux: Fix pinmux command if "pinmux status" command is used without having set dev using "pinmux dev", print pinmux usage Reviewed-by: Simon Glass <sjg@chromium.org>
