path: root/cmd/part.c
2018-09-10cmd: part: use MAX_SEARCH_PARTITIONS for part searchKever Yang
Use Macro instead of hard code. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-03-13cmd: part: Extract common code to separate functionSam Protsenko
Refactor the code for "part start" and "part size" commands to avoid code duplication. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-03-13cmd: part: Allow passing partition name to start and sizeSam Protsenko
Allow passing the partition name to "part start" and "part size" commands, so we can avoid magic numbers in the environment. Consider one real use-case: in include/environment/ti/boot.h we have commands like these: setenv boot_part 9 part start mmc ${mmcdev} ${boot_part} boot_start part size mmc ${mmcdev} ${boot_part} boot_size mmc read ${loadaddr} ${boot_start} ${boot_size} Now suppose that we have changed the partition table and boot_part now is 10. We will need to fix commands above. And anyone who relies on these boot commands, will need to change them accordingly, too (this was an actual case in our lab while testing Linux boot on Android environment). By providing the option to pass partition name instead, we fix mentioned issue, by eliminating the necessity to use magic numbers. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device_and_partition()Simon Glass
Rename this function to blk_get_device_part_str(). This is a better name because it makes it clear that the function returns a block device and parses a string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device() to blk_get_device_by_str()Simon Glass
The current name is too generic. The function returns a block device based on a provided string. Rename it to aid searching and make its purpose clearer. Also add a few comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
