path: root/cmd/osd.c
2021-08-02global: Convert simple_strtoul() with decimal to dectoul()Simon Glass
It is a pain to have to specify the value 10 in each call. Add a new dectoul() function and update the code to use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-08-02global: Convert simple_strtoul() with hex to hextoul()Simon Glass
It is a pain to have to specify the value 16 in each call. Add a new hextoul() function and update the code to use it. Add a proper comment to simple_strtoul() while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-18cmd: Drop use of old sequence numbers in commandsSimon Glass
Several commands use sequence numbers. Update them to use the new ones. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-18dm: Avoid accessing seq directlySimon Glass
At present various drivers etc. access the device's 'seq' member directly. This makes it harder to change the meaning of that member. Change access to go through a function instead. The drivers/i2c/lpc32xx_i2c.c file is left unchanged for now. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-28cmd: Add osd commandsMario Six
Add command to query information from and write text to on-screen display (OSD) devices. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
