path: root/cmd/nvedit.c
2019-12-09net: Always build the string_to_enetaddr() helperJoe Hershberger
Part of the env cleanup moved this out of the environment code and into the net code. However, this helper is sometimes needed even when the net stack isn't included. Move the helper to lib/net_utils.c like it's similarly-purposed string_to_ip(). Also rename the moved function to similar naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Ondrej Jirman <megous@megous.com>
2019-12-06cmd: Migrate from_env() from pxe.c to nvedit.cPatrice Chotard
Migrate from_env() from pxe.c to nvedit.c as it's not pxe specific. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-30cmd: env: extend "env [set|print] -e" to manage UEFI variablesAKASHI Takahiro
With this patch, when setting UEFI variable with "env set -e" command, we will be able to - specify vendor guid with "-guid guid", - specify variable attributes, BOOTSERVICE_ACCESS, RUNTIME_ACCESS, respectively with "-bs" and "-rt", - append a value instead of overwriting with "-a", - use memory as variable's value instead of explicit values given at the command line with "-i address,size" If guid is not explicitly given, default value will be used. Meanwhile, "env print -e," will be modified so that it will NOT dump a variable's value if '-n' is specified. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop the ACTION typedefSimon Glass
Avoid using a typedef here which is unnecessary. Add an 'env_' prefix to both the enum and its members to make it clear that these are related to the environment. Add an ENV prefix to these two flags so that it is clear what they relate to. Also move them to env.h since they are part of the public API. Use an enum rather than a #define to tie them together. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Rename the redundancy flagsSimon Glass
2019-08-11env: Drop the ENTRY typedefSimon Glass
U-Boot is not supposed to use typedef for structs anymore. Also this name is the same as the ENTRY() macro used in assembler files, and 'entry' itself is widely used in U-Boot (>8k matches). Drop the typedef and rename the struct to env_entry to reduce confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move get/set_default_env() to env.hSimon Glass
Move these functions to the new header file and rename set_default_env() to env_set_default() so that it has a consistent env_ prefix. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move set_default_vars to env.hSimon Glass
Move this function to the new header file and rename it so it has an env_ prefix. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: net: Move eth_parse_enetaddr() to net.c/hSimon Glass
This function fits better with the network subsystem, so move it. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move envmatch() to env.hSimon Glass
Move envmatch() over to the new header file. Also rename it to env_match() to better line up with other functions. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move get_env_id() to env.hSimon Glass
Move this function over to the new header file. Also rename it to have an env_ prefix like the other functions. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-07-18env: register erase commandFrank Wunderlich
this patch adds basic changes for adding a erase-subcommand to env with this command the environment stored on non-volatile storage written by saveenv can be cleared. Signed-off-by: Frank Wunderlich <frank-w@public-files.de> squashed fixes - start message with "Erasing" - mark erase-function as optional - env: separate eraseenv from saveenv Suggested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-07-13cmd: nvedit: Add sub-command 'env info'Leo Ruan
Add sub-command 'env info' to display environment information: - env_valid : is environment valid - env_ready : is environment imported into hash table - env_use_default : is default environment using This command can be optionally used for evaluation in scripts: [-d] : evaluate whether default environment is used [-p] : evaluate whether environment can be persisted The result of multiple evaluations will be combined with AND. Signed-off-by: Leo Ruan <tingquan.ruan@cn.bosch.com> Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Do not enable by default] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-11Merge tag 'u-boot-stm32-20190606' of https://github.com/pchotard/u-bootTom Rini
- Add Ethernet support for STM32MP1 - Add saveenv support for STM32MP1 - Add STM32MP1 Avenger96 board support - Add SPI driver suport for STM32MP1 - Add watchdog support for STM32MP1 - Update power supply check via USB TYPE-C for STM32MP1 discovery board
2019-06-06env: enable saveenv command when one CONFIG_ENV_IS_IN is activatedPatrick Delaunay
Introduce ENV_IS_IN_DEVICE to test if one the CONFIG_ENV_IS_IN_ is defined and support the command saveenv even if CONFIG_ENV_IS_NOWHERE is activated Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-06-04cmd: env: add -nv option for UEFI non-volatile variableAKASHI Takahiro
With this option, -nv, at "setenv -e" command, a variable will be defined as non-volatile. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-25cmd: env: add "-e" option for handling UEFI variablesAKASHI Takahiro
"env [print|set] -e" allows for handling uefi variables without knowing details about mapping to corresponding u-boot variables. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-15cmd: nvedit: use correct format codeHeinrich Schuchardt
len is defined as unsigned. So use %u for printf(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-09-30cmd: env: Fix CRC calculation for 'env export -c -s'Neil Stainton
Fix failure to reimport exported checksummed, size constrained data block. 'env export -c' command ignores optional -s size argument when calculating checksum causing subsequent 'env import -c' to fail. Signed-off-by: Neil Stainton <nstainton@asl-control.co.uk>
2018-07-20cmd: nvedit: env import can now import only variables passed as parametersQuentin Schulz
While the `env export` can take as parameters variables to be exported, `env import` does not have such a mechanism of variable selection. Let's add the ability to add parameters at the end of the command for variables to be imported. Every env variable from the env to be imported passed by parameter to this command will override the value of the variable in the current env. If a variable exists in the current env but not in the imported env, if this variable is passed as a parameter to env import, the variable will be unset ONLY if the -d option is passed to env import, otherwise the current value of the variable is kept. If a variable exists in the imported env, the variable in the current env will be set to the value of the one from the imported env. All the remaining variables are left untouched. As the size parameter of env import is positional but optional, let's add the possibility to use the sentinel '-' for when we don't want to give the size parameter (when the env is '\0' terminated) but we pass a list of variables at the end of the command. env import addr env import addr - env import addr size env import addr - foo1 foo2 env import addr size foo1 foo2 are all valid. env import -c addr env import -c addr - env import -c addr - foo1 foo2 are all invalid because they don't pass the size parameter required for checking, while the following are valid. env import addr size env import addr size foo1 foo2 Nothing's changed for the other parameters or the overall behaviour. One of its use case could be to load a secure environment from the signed U-Boot binary and load only a handful of variables from an other, unsecure, environment without completely losing control of U-Boot. Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2018-07-20env: add the same prefix to error messages to make it detectable by testsQuentin Schulz
The error message should start with `## Error: ` so that it's easily detectable by tests without needing to have a complex regexp for matching all possible error message patterns. Let's add the `## Error: ` prefix to the error messages since it's the one already in use. Suggested-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2018-07-19env: common: accept flags on reset to default envYaniv Levinsky
The function set_default_env() sets the hashtable flags for import_r(). Formally set_default_env() doesn't accept flags from its callers. In practice the caller can (un)set the H_INTERACTIVE flag, but it has to be done using the first character of the function's string argument. Other flags like H_FORCE can't be set by the caller. Change the function to accept flags argument. The benefits are: 1. The caller will have to explicitly set the H_INTERACTIVE flag, instead of un-setting it using a special char in a string. 2. Add the ability to propagate flags from the caller to himport(), especially the H_FORCE flag from do_env_default() in nvedit.c that currently gets ignored for "env default -a -f" commands. 3. Flags and messages will not be coupled together. A caller will be able to set flags without passing a string and vice versa. Please note: The propagation of H_FORCE from do_env_default() does not introduce any functional changes, because currently himport_r() is set to destroy the old environment regardless if H_FORCE flag is set or not. More changes are needed to utilize the propagation of H_FORCE. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: set H_INTERACTIVE in do_env_defaultYaniv Levinsky
The function set_default_vars() in common.c adds H_INTERACTIVE to the h_import() flag, but the function has no way of telling if the command actually was user directed like this flag suggest. The flag should be set by the calling function do_env_default() in nvedit.c instead, where the command is certainty user directed. Move the H_INTERACTIVE flag from set_default_vars() to do_env_default(). Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: propagate envflag to set_default_varsYaniv Levinsky
The env_flag in do_env_default() doesn't get propagated and therefore gets ignored by himport_r(). This breaks to ability to "forcibly" reset variables to their default values using the environment command. Scenario example of the problem: # setenv kernel uImage # setenv .flags kernel:so # env default -f kernel ## Error: Can't overwrite "kernel" himport_r: can't insert "kernel=zImage" into hash table Change the call path so it will pass the flag correctly. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2018-07-19cmd: nvedit: rename flags in do_env_defaultYaniv Levinsky
The naming convention for flags in nvedit.c is: * The hashtable flag (defined in search.h) is named "env_flag" * The command flag argument (defined in command.h) is named "flag" This convention is kept in functions like do_env_print(), do_env_set() and do_env_delete(), but not in do_env_default(). Rename the hashtable flag in do_env_default() from "flag" to "env_flag". Rename the command flag in do_env_default() from "__flag" to "flag". No functional change. Signed-off-by: Yaniv Levinsky <yaniv.levinsky@compulab.co.il> Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
2018-06-13u-boot: Fix several typosShyam Saini
's/environemnt/environment/' and 's/Environemnt/Environment/' Signed-off-by: Shyam Saini <shyam@amarulasolutions.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-31cmd: nvedit: env_get_f must check for env_get_char error codesSimon Goldschmidt
env_get_f calls env_get_char to load single characters from the environment. However, the return value of env_get_char was not checked for errors. Now if the env driver does not support the .get_char call, env_get_f did not notice this and looped over the whole size of the environment, calling env_get_char over 8000 times with the default settings, just to return an error in the end. Fix this by checking if env_get_char returns < 0. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-01-27cmd: nvedit: Get rid of the env lookupMaxime Ripard
The nvedit command is the only user of env_driver_lookup_default outside of the environment code itself, and it uses it only to print the environment it's about to save to during env save. As we're about to rework the environment to be able to handle multiple environment sources, we might not have an idea of what environment backend is going to be used before trying (and possibly failing for some). Therefore, it makes sense to remove that message and move it to the env_save function itself. As a side effect, we also can get rid of the call to env_driver_lookup_default that is also about to get refactored. Reviewed-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-16env: Drop CONFIG_ENV_IS_IN_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-07cmd/gpt.c, cmd/nvedit.c, tools/fit_image.c: Rework recent fixes for CoverityTom Rini
The recent changes to these files did not completely fix the previous issues, or introduced different (minor) issues. In cmd/gpt.c we need to dereference str_disk_guid to be sure that malloc worked. In cmd/nvedit.c we need to be careful that we can also fit in that leading space when adding to the string. And in tools/fit_image.c we need to re-work the error handling slightly in fit_import_data() so that we only call munmap() once. We have two error paths here, one where we have an fd to close and one where we do not. Adjust labels to match this. Reported-by: Coverity (CID: 167366, 167367, 167370) Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-06cmd/nvedit.c: Update input handling to cover overflow casesTom Rini
When we have multiple messages provided, we need to be sure that we do not exceed the length of our 'message' buffer. In the for loop, make sure that pos is not larger than message. Only copy in at most however much of the message buffer remains. Finally, if we have not reached the end of the message buffer, put in a space and NULL, and if we have, ensure the buffer is now NULL termined. Reported-by: Coverity (CID: 165116) Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Drop saveenv() in favour of env_save()Simon Glass
Use the env_save() function directly now that there is only one implementation of saveenv(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Drop the env_name_spec globalSimon Glass
Add a name to the driver and use that instead of the global variable declared by each driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-12cmd: nvedit: bring error message in sync with condition under which it appearsLothar Waßmann
The list of symbols listed in the error message for missing Kconfig symbols is out of sync with the symbols actually tested. Add the missing symbols and reorder their appearance to be in sync with the #if statement for easier checking. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
2017-05-12common: env: remove superfluous assignmentxypron.glpk@gmx.de
The value assigned to variable 'value' is never used. The problem was indicated by clang scan-build. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-04-18common: env: support sata devicePeng Fan
Introduce env support for sata device. 1. Implement write_env/read_env/env_relocate_spec/saveenv/sata_get_env_dev 2. If want to enable this feature, define CONFIG_ENV_IS_IN_SATA, and define CONFIG_SYS_SATA_ENV_DEV or implement your own sata_get_ev_dev. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Stuart Longland <stuartl@vrt.com.au> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14common: Add support for environment file in EXT4.Stuart Longland
This is an enhancement that permits storing the environment file on an EXT4 partition such as the root filesystem. It is based on the existing FAT environment file code.
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
