path: root/cmd/net.c
2022-01-21net: Drop #ifdefs with CONFIG_BOOTP_SERVERIPSimon Glass
Use IS_ENABLED() instead, to reduce the number of build paths. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2021-08-02global: Convert simple_strtoul() with hex to hextoul()Simon Glass
It is a pain to have to specify the value 16 in each call. Add a new hextoul() function and update the code to use it. Add a proper comment to simple_strtoul() while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-07-06cmd: net: add a 'net list' command to list network devsTim Harvey
In a system with multiple network controllers it can be difficult to know the names of the various devices available. This is especially true for USB ether devices as they do not display device names upon detection. This is being added as a net sub-system in case other commands may want to be added or moved here. Note that this is only enabled for DM_ETH Example: U-Boot > net net - NET sub-system Usage: net list - list available devices U-Boot > net list eth0 : ethernet@2188000 00:d0:12:98:f5:47 active eth1 : e1000#0 00:d0:12:98:f5:48 eth2 : asix_eth 8c:ae:4c:f5:84:9d eth3 : asix_eth 8c:ae:4c:f9:41:e3 Signed-off-by: Tim Harvey <tharvey@gateworks.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2020-09-30sntp: use udp frameworkPhilippe Reynes
This commits update the support of sntp to use the framework udp. This change allows to remove all the reference to sntp in the main network file net/net.c. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-06-12net: Fix error if some network features are disabledKrebs, Olaf
If 'CONFIG_CMD_TFTPBOOT' or 'CONFIG_CMD_BOOTP' are disabled, the usage must be disabled, too! Signed-off-by: Olaf Krebs <olaf.krebs@emh-metering.com> CC: Joe Hershberger <joe.hershberger@ni.com>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop bootstage.h from common headerSimon Glass
Move this fairly uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move the image globals into image.hSimon Glass
These three globals relate to image handling. Move them to the image header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17image: Rename load_addr, save_addr, save_sizeSimon Glass
These global variables are quite short and generic. In fact the same name is more often used locally for struct members and function arguments. Add a image_ prefix to make them easier to distinguish. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-26net: Read bootfile from env on netboot_common()Joe Hershberger
Instead of depending on a env callback for bootfile, read it explicitly. We do this because the bootfile can be specified on the command line and if it is, we will overwrite the internal variable. If a netboot_common() is called again with no bootfile parameter, we want to use the one in the environment. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-02net: Prefer command line argumentsAlexander Graf
We can call commands like dhcp and bootp without arguments or with explicit command line arguments that really should tell the code where to look for files instead. Unfortunately, the current code simply overwrites command line arguments in the dhcp case with dhcp values. This patch allows the code to preserve the command line values if they were set on the command line. That way the semantics are slightly more intuitive. The reason this patch does that by introducing a new variable is that we can not rely on net_boot_file_name[0] being unset, as today it's completely legal to call "dhcp" and afterwards run "tftp" and expect the latter to repeat the same query as before. I would prefer not to break that behavior in case anyone relies on it. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-13net: Make CMD_NET a menuconfigJoe Hershberger
Previously, CMD_NET was an alias for 2 commands (bootp and tftpboot) and they we not able to be disabled. Separate out those 2 commands and move CMD_NET up to the menu level, which more accurately represents the code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-07net: add static to do_tftpput()Masahiro Yamada
This is only used in cmd/net.c Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-27cmd: net: fix function name in commentBaruch Siach
In commit 7044c6bb6 (net: cosmetic: Clean up DHCP variables and functions) BootpCopyNetParams() was renamed to store_net_params(). Update the reference in comment. Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2016-10-13net: Fix cache misalignment message after network load operationsPeter Chubb
After any operation that downloads a file (e.g., pxe get, or dhcp), the buffer containing the downloaded data is flushed. This is unnecessary and annoying. Unnecessary, because the network driver should already have fliushed the cache for the DMAed area, and annoying because it generates a cache misalignment message. Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
