path: root/cmd/nand.c
2017-01-11cmd_writebcb_mx7: add command to write FCB and DBBT for i.MX 7Max Krummenacher
Code mostly ported from imx-kobs-5.3. MTD partitioning is set accordingly. writebcb: Write Boot Control Block (FCB and DBBT) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> [ported to U-Boot 2016.11] Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-01nand: Fix some more NULL name testsScott Wood
Now that nand_info[] is an array of pointers we need to test the pointer itself rather than using name as a proxy for NULLness. Fixes: b616d9b0a708eb9 ("nand: Embed mtd_info in struct nand_chip") Signed-off-by: Scott Wood <oss@buserror.net> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Tony Lindgren <tony@atomide.com>
2016-09-01nand: Fix nand info for no deviceTony Lindgren
Looks like we have few more places where we're testing for nand_info[i]->name. We can now use just test for nand_info[i] instead. This fixes a data abort on devices with no NAND when doing nand info. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-26nand: Fix set_dev checks for no deviceTony Lindgren
If we do nand device 0 command in u-boot on a device that has NAND support enabled but no NAND chip, we can get data abort at least on omaps. Fix the issue by replacing the check with nand_info[dev] as suggested by Scott Wood. The check for name existed before because before the array-to-pointer conversion there was no way to directly test nand_info[dev] for emptiness. Signed-off-by: Tony Lindgren <tony@atomide.com>
2016-07-24cmd, nand: add an option to disable the verification when writing in raw modeBoris Brezillon
Modern NANDs do not guarantee that data written in raw mode will not contain bitflips just after writing them. This is fine since the number of bitflips should be rather low and thus fixable by the ECC engine, but since we are reading data in raw mode to verify if they match the input data we cannot prevent failures if some bits are flipped. The option of using standard mode to verify the data is not acceptable either, since one of the usage of raw mode is to allow flashing images that do not respect the standard NAND page layout or the default ECC config (this is the case on Allwinner platforms, where the ROM code tests several hardcoded configs, which are not necessarily matching the NAND characteristics). Add an extension to the nand write.raw command allowing one to disable the verification step. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-19nand: extend nand tortureMax Krummenacher
nand torture currently works on exactly one nand block which is specified by giving the byteoffset to the beginning of the block. Extend this by allowing for a second parameter specifying the byte size to be tested. e.g. ==> nand torture 1000000 NAND torture: device 0 offset 0x1000000 size 0x20000 (block size 0x20000) Passed: 1, failed: 0 ==> nand torture 1000000 40000 NAND torture: device 0 offset 0x1000000 size 0x40000 (block size 0x20000) Passed: 2, failed: 0 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> [scottwood: fix usage to show size as optional, and add misssing braces] Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Add+use mtd_to/from_nand and nand_get/set_controller_dataScott Wood
These functions are part of the Linux 4.6 sync. They are being added before the main sync patch in order to make it easier to address the issue across all NAND drivers (many/most of which do not closely track their Linux counterparts) separately from other merge issues. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Remove nand_info_t typedefScott Wood
This typedef serves no purpose other than causing confusion with struct nand_chip. Signed-off-by: Scott Wood <oss@buserror.net>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
