path: root/cmd/license.c
2017-02-08cmd: rework "license" commandMasahiro Yamada
The previous commit ("add a new command to show .config contents") improves the basic infrastructure of "embed a compressed file into the U-Boot image, and print it by a command". The same pattern for the "license" command. This commit reworks the command to improve the following: [1] Improve log style Kbuild style log GZIP cmd/license_data.gz CHK cmd/license_data_gz.h UPD cmd/license_data_gz.h CHK cmd/license_data_size.h UPD cmd/license_data_size.h instead of the bare Make log: cat ./Licenses/gpl-2.0.txt | gzip -9 -c | \ tools/bin2header license_gzip > ./include/license.h [2] Collect related code into the "cmd" directory Prior to this commit, the license.h was created by tools/Makefile, placed under the "include" directory, included from cmd/license.c, and deleted by the top-level Makefile. It is not a good idea to scatter related code. [3] Drop the fixed-malloc size LICENSE_MAX Just allocate the minimum required size of buffer because we know the size of the original gpl-2.0.txt. [4] Fix more issues Terminate the buffer with zero to prevent puts() from over-running. Add "static" to do_license. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-22cmd: Fix license commandTom Rini
The license command isn't usually built and has a few problems: - The rules to generate license.h haven't worked in a long time, re-write these based on the bmp_logo.h rules. - 'tok' is unused and the license text size has increased - bin2header.c wasn't grabbing unistd.h to know the prototype for read(). Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
