path: root/cmd/legacy_led.c
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-14led: Mark existing driver as legacySimon Glass
The existing 'led' command does not support driver model. Rename it to indicate that it is legacy code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Ziping Chen <techping.chan@gmail.com>
2017-04-14sandbox: Add some test LEDsSimon Glass
Add some LEDs to the standard sandbox device tree. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Ziping Chen <techping.chan@gmail.com>
