path: root/cmd/itest.c
2021-08-02global: Convert simple_strtoul() with hex to hextoul()Simon Glass
It is a pain to have to specify the value 16 in each call. Add a new hextoul() function and update the code to use it. Add a proper comment to simple_strtoul() while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-01command: Add constants for cmd_get_data_size string / errorSimon Glass
At present these values are open-coded in a few places. Add constants so the meaning is clear. Also add a comment to cmd_get_data_size() Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-10-11cmd: itest: add support for .q size specifierMarek Szyprowski
Add support for quad (64bits) memory access specifier. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-17cmd: itest: correct calculus for long formatSebastien Colleur
itest shell command doesn't work correctly in long format when doing comparaison due to wrong mask value calculus that overflow on 32 bits values. Signed-off-by: Sebastien Colleur <sebastienx.colleur@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-27cmd: replace the cast of the memory access to a fixed bit type in itestKunihiko Hayashi
This patch fixes a bug that long word(.l) memory access in 'itest' command reads the 8bytes of the actual memory on 64-bit architecture. The cast to the memory pointer should use a fixed bit type. Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-09itest: allow map_physmem to return 0 in limited casesStephen Warren
On some systems, RAM starts at address 0. If the user executes itest against address 0 on such a system, it will call map_physmem(0, ...) which will return 0 back; mapping only changes the address on sandbox. This causes itest to believe map_physmem() has failed, and hence fails the comparison. Fix itest so that it allows map_physmem() to return 0 /if/ the orignal address passed to it was also 0. This fixes "tegra-uboot-flasher flash" on Tegra20. This has the disadvantage that on sandbox, failed mapping attempts for address 0 are not detected. Instead, should the code only call map_physmem() on sandbox? Or, should map_physmem() return its error status some other way. Or, should the special case only be allowed on systems where the base of RAM is 0 somehow? Fixes: 7861204c9af7 ("itest: make memory access work under sandbox") Signed-off-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
