path: root/cmd/io.c
2017-05-12cmd/io.c: Fix comparison of unsigned expression warningTom Rini
The function cmd_get_data_size() returns an int and not unsigned. So we should assign it to an int rather than unsigned so that we can later compare the return value. Reported by clang-3.8. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
