path: root/cmd/host.c
2021-12-05sandbox: Drop CONFIG_HOST_MAX_DEVICESSimon Glass
This can go in the related header file. Drop the CONFIG option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2021-08-02global: Convert simple_strtoul() with hex to hextoul()Simon Glass
It is a pain to have to specify the value 16 in each call. Add a new hextoul() function and update the code to use it. Add a proper comment to simple_strtoul() while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-27sandbox: Provide a way to bind fixed/removeable devicesSimon Glass
At present when a file is bound to a host device it is always marked as removeable. Arguably the device is removeable, since it can be unbound at will. However while it is bound, it is not considered removable by the user. Also it is useful to be able to model both fixed and removeable devices for code that distinguishes them. Add a -r flag to the 'host bind' command and plumb it through to provide this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-27sandbox: Update do_host_bind() argument countingSimon Glass
Remove the 'bind' subcommand before processing the arguments. This will make it easier to add an optional flag. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-03-27sandbox: Disintangle declarations in do_host_bind()Simon Glass
This function has a strange mix of declarations and argument parsing which is a bit hard to follow and harder to modify. Separate out the declarations at the start of the function and adjust the ordering of the code slightly. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-13dm: treewide: Rename dev_get_platdata() to dev_get_plat()Simon Glass
Rename this to be consistent with the change from 'platdata'. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-07-28cmd: host: return value of do_host_bind()Heinrich Schuchardt
When trying to bind to a non-existent file the following output is displayed: => host bind 0 non_existent Failed to access host backing file 'non_existent' exit not allowed from main input shell. The last line is quite unexpected and due to an incorrect return value. If do_host_bind() fails, return CMD_RET_FAILURE (= 1). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-10-06cmd: host: fix seg fault at "host info"AKASHI Takahiro
With the patch below applied, host_block_dev structure was switched to be placed in platdata rather than priv. The command "host info" must be aligned with this change. Otherwise, we will see "Segmentation Fault." Fixes: 8f994c860d91 ("sandbox: blk: Switch to use platdata_auto_alloc_size for the driver data") Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-11-26sandbox: Drop the deprecated 'sb' commandSimon Glass
The old 'sb' command was deprecated in 2015 and replaced with 'host'. Remove the remaining users and the command, so that the name is available for other purposes. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-20cmd/host: add missing \n in help textSébastien Szymanski
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2016-09-18sandbox: Add "host size" hostfs command for fs testStefan Brüns
This complements the size/fatsize/ext4size commands added in commit cf6598193aed5de8855eaf70c1994f2bc437255a load, save and ls are already implemented for hostfs, now tests can cover the same operations on hostfs and emulated block devices. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: sandbox: Add driver-model block-device support for sandboxSimon Glass
Update the host driver to support driver model for block devices. A future commit will remove the old code, but for now it is useful to be able to use it both with and without CONFIG_BLK. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
