path: root/cmd/host.c
2016-09-18sandbox: Add "host size" hostfs command for fs testStefan Brüns
This complements the size/fatsize/ext4size commands added in commit cf6598193aed5de8855eaf70c1994f2bc437255a load, save and ls are already implemented for hostfs, now tests can cover the same operations on hostfs and emulated block devices. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: sandbox: Add driver-model block-device support for sandboxSimon Glass
Update the host driver to support driver model for block devices. A future commit will remove the old code, but for now it is useful to be able to use it both with and without CONFIG_BLK. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
