path: root/cmd/help.c
2019-07-29Drop linker-generated array creation when CONFIG_CMDLINE is disabledAndrej Rosano
Linker generated array entry is not needed when the command line is disabled. Remove this code in that case. This is required as the commit 80a48dd47e3bf3ede676fae5a630cb6c80de3e69 breaks the linking stage when CONFIG_CMDLINE=n: .. LDS u-boot.lds LD u-boot u-boot contains unexpected relocations: R_ARM_NONE R_ARM_RELATIVE make: *** [Makefile:1775: checkarmreloc] Error 1 Signed-off-by: Andrej Rosano <andrej.rosano@f-secure.com>
2019-01-15common: command: Rework the 'cmd is repeatable' logicBoris Brezillon
The repeatable property is currently attached to the main command and sub-commands have no way to change the repeatable value (the ->repeatable field in sub-command entries is ignored). Replace the ->repeatable field by an extended ->cmd() hook (called ->cmd_rep()) which takes a new int pointer to store the repeatable cap of the command being executed. With this trick, we can let sub-commands decide whether they are repeatable or not. We also patch mmc and dtimg who are testing the ->repeatable field directly (they now use cmd_is_repeatable() instead), and fix the help entry manually since it doesn't use the U_BOOT_CMD() macro. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01Drop command-processing code when CONFIG_CMDLINE is disabledSimon Glass
Command parsing and processing code is not needed when the command line is disabled. Remove this code in that case. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
