path: root/cmd/fs.c
2016-04-18efi_loader: Pass file path to payloadAlexander Graf
The payload gets information on where it got loaded from. This includes the device as well as file path. So far we've treated both as the same thing and always gave it the device name. However, in some situations grub2 actually wants to find its loading path to find its configuration file. So let's split the two semantically separte bits into separate structs and pass the loaded file name into our payload when we load it using "load". Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-15efi_loader: Pass proper device path in on bootAlexander Graf
EFI payloads can query for the device they were booted from. Because we have a disconnect between loading binaries and running binaries, we passed in a dummy device path so far. Unfortunately that breaks grub2's logic to find its configuration file from the same device it was booted from. This patch adds logic to have the "load" command call into our efi code to set the device path to the one we last loaded a binary from. With this grub2 properly detects where we got booted from and can find its configuration file, even when searching by-partition. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
