path: root/cmd/fdt.c
2020-07-09cmd: fdt: remove CMD_FDT_MAX_DUMPHeinrich Schuchardt
When printing the device tree we want to get an output that can be used as input for the device tree compiler. This requires that we do not write bogus lines like pcie@10000000 { interrupt-map = * 0x4000127c [0x00000280]; For instance the QEMU virt device has a property interrupt-map with 640 bytes which exceeds CMD_FDT_MAX_DUMP=64. So lets do away with the artificial limitation to 64 bytes. As indicated in commit f0a29d43313c ("fdt: Limit printed hex in fdt print and list commands") if a device tree contains binary blobs, it may still be desirable to limit the output length. Provide environment variable fdt_max_dump for this purpose. Fixes: 5d927b428622 ("Kconfig: Drop CONFIG_CMD_FDT_MAX_DUMP") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop image.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16fdt: Fix 'system' commandTom Warren
'fdt systemsetup' wasn't working, due to the fact that the 'set' command was being parsed in do_fdt() by only testing for the leading 's' instead of "se", which kept the "sys" test further down from executing. Changed to test for "se" instead, now 'fdt systemsetup' works (to test the ft_system_setup proc w/o having to boot a kernel). Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-11-29cmd, fdt: add subcommand "get" to fdt headerHeiko Schocher
store fdt header member with name <member> in U-Boot Environment variable with name <var>. for example to get the total length of the fdt and store it in filesize, call: fdt header get filesize totalsize For membernames look into fdt header definition at scripts/dtc/libfdt/libfdt.h Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-20cmd: fdt: Fix fdt address information after the movementHiroyuki Yokoyama
This patch fixes the address information of fdt. wrong case: => fdt addr 0x48000000 => fdt move 0x48000000 0x41000000 0xa000 => fdt addr The address of the fdt is 48000000 Active address in this case is 0x41000000. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-10fdt: add call to ft_board_setup_ex() for ks2 boardsNicholas Faustini
When updating the board FDT, some of the operations are performed by ft_board_setup_ex() and should be executed also by the fdt command. Signed-off-by: Nicholas Faustini <nicholas.faustini@azcomtech.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-16cmd/fdt.c align data buffer to avoid unaligned word accessBernhard Messerklinger
Since the compiler is free to place a char array to any address in memory (in this case the stack), also to a non word aligned address the function "fdt_prop_parse" runs into troubles upon it wants to write some (fdt32_t *) to such a variable (if it has been placed to a none word aligned address). To avoid this we tell the compiler to always align this scratchpad to a word aligned address. Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-15fdt: Switch to using the verbose overlay application methodPantelis Antoniou
The verbose overlay application method prints out more helpful messages, so switch to it. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-09-04fdt: fix 'prop (...) not found!' error in 'fdt set' commandHannes Schmelzer
This commit brings things back to the well known working state of the command. - With commit 9620d87259572ef21f0df60988d9a932ca673779 (cmd/fdt: support single value replacement within an array) there was an error introduced modifying (inserting) a property to a device-tree node. fdt_getprop(...) returnes a len with -1 for a non-existing property, but a memcpy with len -1 isn't a good idea and things went wrong (crash). - Some times later Tom did repair this with commit 99bb38e2cce9d99238458e0f6d1880c6d2e80a4d (fdt: Check for NULL return from fdt_getprop in 'fdt set') This repairs the crash but the behaviour of the command isn't like before, it makes it impossible to insert a property. - Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11fdt: Check for NULL return from fdt_getprop in 'fdt set'Tom Rini
While the previous pass through fixed one place where we knew that fdt_getprop would be given a positive len, in the case of 'fdt set' we do not, so check that we did no get NULL from fdt_getprop(). Cc: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 163249) Fixes 72c98ed1ab48 ("fdt: Add a check to do_fdt() for coverity") Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-12fdt: Add a check to fdt_print() for coveritySimon Glass
We know that fdt_getprop() does not return NULL when len is > 0 but coverity does not. Add an extra check to keep it happy. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 163248)
2017-06-12fdt: Add a check to do_fdt() for coveritySimon Glass
We know that fdt_getprop() does not return NULL when len is > 0 but coverity does not. Add an extra check to keep it happy. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 163249) Fixes: bc80295b (fdt: Add get commands to fdt)
2017-06-09cmd/fdt: support single value replacement within an arrayHannes Schmelzer
With this commit we can modify single values within an array of a dts property. This is useful if we have for example a pwm-backlight where we want to modifiy the pwm frequency per u-boot script. The pwm is described in dts like this: backlight { pwms = <0x0000002b 0x00000000 0x004c4b40>; }; For changing the frequency, here the 3rd parameter, we simply type: fdt set /backlight pwms <? ? 0x1E8480>; For doing all this we: - backup the property content into our 'SCRATCHPAD' - only modify the array-cell if the new content doesn't start with '?' Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_CMD_FDT_MAX_DUMPSimon Glass
This option is not used by any board. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-14cmd/fdt: Make fdt get value endian-safe for single-cell propertiesAndreas Färber
On a Raspberry Pi 2 disagreements on cell endianness can be observed: U-Boot> fdt print /soc/gpio@7e200000 phandle phandle = <0x0000000d> U-Boot> fdt get value myvar /soc/gpio@7e200000 phandle; printenv myvar myvar=0x0D000000 Fix this by always treating the pointer as BE and converting it in fdt_value_setenv(), like its counterpart fdt_parse_prop() already does. Consistently use fdt32_t, fdt32_to_cpu() and cpu_to_fdt32(). Fixes: bc80295 ("fdt: Add get commands to fdt") Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Gerald Van Baren <gvb@unssw.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Acked-by: Simon Glass <sjg@chromium.org>
2017-01-13cmd: fdt: Print error message when fdt application failsStefan Agner
There are lots of reason why a FDT application might fail, the error code might give an indication. Let the error code translate in a error string so users can try to understand what went wrong. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-12-02cmd/fdt: fix uncallable systemsetup commandFabien Parent
The function that is processing the 'fdt' parameters is one big if-else if. In order to be able to type command faster only the first few letter are checked to know which block of code to execute. For systemsetup, the block of code that was executed was always the wrong one and ended up in a failure. } else if (argv[1][0] == 's') { process "fdt set" command } else if (strncmp(argv[1], "sys", 3) == 0) { process "fdt systemsetup" command. } When typing "fdt systemsetup", the code that was executed was the code for "fdt set". This commit fix this issue by moving the "else if" for systemsetup before the else if for "fdt set". This allow us to keep compatibility with any script that make use of "fdt s" to set node values. Signed-off-by: Fabien Parent <fparent@baylibre.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-13cmd/fdt: add possibilty to have 'extrasize' on fdt resizeHannes Schmelzer
Sometimes devicetree nodes and or properties are added out of the u-boot console, maybe through some script or manual interaction. The devicetree as loaded or embedded is quite small, so the devicetree has to be resized to take up those new nodes/properties. In original the devicetree was only extended by effective 4 * add_mem_rsv. With this commit we can add an argument to the "fdt resize" command, which takes the extrasize to be added. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-20cmd: fdt: add fdt overlay application subcommandMaxime Ripard
The device tree overlays are a good way to deal with user-modifyable boards or boards with some kind of an expansion mechanism where we can easily plug new board in (like the BBB or the raspberry pi). However, so far, the usual mechanism to deal with it was to have in Linux some driver detecting the expansion boards plugged in and then request these overlays using the firmware interface. That works in most cases, but in some cases, you might want to have the overlays applied before the userspace comes in. Either because the new board requires some kind of an early initialization, or because your root filesystem is accessed through that expansion board. The easiest solution in such a case is to simply have the component before Linux applying that overlay, removing all these drawbacks. Reviewed-by: Stefan Agner <stefan@agner.ch> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20cmd: fdt: Narrow the check for fdt addrMaxime Ripard
The current code only checks if the fdt subcommand is fdt addr by checking whether it starts with 'a'. Since this is a pretty widely used letter, narrow down that check a bit. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-05-05Fix various typos, scattered over the code.Robert P. J. Day
Spelling corrections for (among other things): * environment * override * variable * ftd (should be "fdt", for flattened device tree) * embedded * FTDI * emulation * controller
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
