When host issues "fastboot reboot fastboot", it's expected that the
board drops the USB connection before resetting.
On some boards, such as Khadas VIM3L and SEI610, this is not the case.
We observe the following error:
$ fastboot reboot fastboot
Rebooting into fastboot OKAY [ 0.004s]
fastboot: error: Failed to boot into userspace fastboot; one or more components might be unbootable.
This does not happen when we use the RST button on the board.
It can be reproduced in linux with:
# echo b > /proc/sysrq-trigger
In this case, we hit a undefined hardware behavior, where D+ and D-
are in an unknown state. Therefore the host can't detect usb
disconnection.
Make sure we always call usb_gadget_release() when a "fastboot reboot"
command is issued.
Note: usb_gadget_release() should be called before g_dnl_unregister()
because g_dnl_unregister() triggers a complete() call on each
endpoint (thus calling do_reset()).
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Globally replace all occurances of WATCHDOG_RESET() with schedule(),
which handles the HW_WATCHDOG functionality and the cyclic
infrastructure.
Tested-by: Tom Rini <trini@konsulko.com> [am335x_evm, mx6cuboxi, rpi_3,dra7xx_evm, pine64_plus, am65x_evm, j721e_evm]
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
Move this uncommon header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Watchdog is not handled while waiting for fastboot commands.
Tested on a i.MX6 ULL EVK board.
Signed-off-by: Sean Nyekjaer <sean@geanix.com>
Add 2 functions to wrap the calls to board_usb_init() and
board_usb_cleanup().
This is a preparatory work for DM support for UDC drivers (DM_USB_GADGET).
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
In case when user provides '-' as USB controller index, like this:
=> fastboot -
data abort occurs in strcmp() function in do_fastboot(), here:
if (!strcmp(argv[1], "udp"))
(tested on BeagleBone Black).
That's because argv[1] is NULL when user types in the '-', and null
pointer dereference occurs in strcmp() (which is ok according to C
standard specification). So we must validate user input to prevent such
behavior.
While at it, check also the result of strtoul() function and handle
error cases properly.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
After the commit 9b643e312d52 ("treewide: replace with error() with
pr_err()"), there are some pr_err() with no line break. Add missing
line breaks.
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Merge UDP fastboot support from AOSP:
https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Signed-off-by: Alex Deymo <deymo@google.com>
Signed-off-by: Jocelyn Bohr <bohr@google.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
U-Boot widely uses error() as a bit noisier variant of printf().
This macro causes name conflict with the following line in
include/linux/compiler-gcc.h:
# define __compiletime_error(message) __attribute__((error(message)))
This prevents us from using __compiletime_error(), and makes it
difficult to fully sync BUILD_BUG macros with Linux. (Notice
Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().)
Let's convert error() into now treewide-available pr_err().
Done with the help of Coccinelle, excluing tools/ directory.
The semantic patch I used is as follows:
// <smpl>
-error
+pr_err
// </smpl>
[trini: Re-run Coccinelle]
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
