It is a pain to have to specify the value 10 in each call. Add a new
dectoul() function and update the code to use it.
In case exit is called in a script without parameter, the command
returns -2 ; in case exit is called with a numerical parameter,
the command returns -2 and lower. This leads to the following problem:
=> setenv foo 'echo bar ; exit 1' ; run foo ; echo $?
bar
0
=> setenv foo 'echo bar ; exit 0' ; run foo ; echo $?
bar
0
=> setenv foo 'echo bar ; exit -2' ; run foo ; echo $?
bar
0
That is, no matter what the 'exit' command argument is, the return
value is always 0 and so it is not possible to use script return
value in subsequent tests.
Fix this and simplify the exit command such that if exit is called with
no argument, the command returns 0, just like 'true' in cmd/test.c. In
case the command is called with any argument that is positive integer,
the argument is set as return value.
bar
1
bar
0
bar
0
Note that this does change ABI established in 2004 , although it is
unclear whether that ABI was originally OK or not.
Fixes: c26e454dfc6
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
