path: root/cmd/disk.c
2016-09-09cmd: Rework disk.c usageTom Rini
We only need the function found in cmd/disk.c when we have IDE, SCSI or USB_STORAGE enabled. While the first two are easy to get right, in the 3rd case we assume that the set of cases where we do have USB and do not enable USB_STORAGE are small enough that we can take the small bloat of un-discarded strings on gcc prior to 6.x Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27cmd: disk: Fix unused variable warningMarek Vasut
If serial support is not compiled into U-Boot, which may be the case for some SPL builds, the following warning will be generated in disk.c: cmd/disk.c: In function 'common_diskboot': cmd/disk.c:16:6: warning: variable 'dev' set but not used [-Wunused-but-set-variable] int dev, part; ^ The warning is a result of printf() calls being optimized away, and thus the whole dev variable becomes indeed unused. Mark the variable as __maybe_unused . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14Merge git://git.denx.de/u-boot-dmTom Rini
2016-03-14dm: block: Adjust device calls to go through helpers functionSimon Glass
To ease conversion to driver model, add helper functions which deal with calling each block device method. With driver model we can reimplement these functions with the same arguments. Use inline functions to avoid increasing code size on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: block: Rename device number member dev to devnumSimon Glass
This is a device number, and we want to use 'dev' to mean a driver model device. Rename the member. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device_and_partition()Simon Glass
Rename this function to blk_get_device_part_str(). This is a better name because it makes it clear that the function returns a block device and parses a string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
