At present this function does not accept a size for the FIT. This means
that it must be read from the FIT itself, introducing potential security
risk. Update the function to include a size parameter, which can be
invalid, in which case fit_check_format() calculates it.
For now no callers pass the size, but this can be updated later.
Also adjust the return value to an error code so that all the different
types of problems can be distinguished by the user.
Reported-by: Bruce Monroe <bruce.monroe@intel.com>
Reported-by: Arie Haenel <arie.haenel@intel.com>
Reported-by: Julien Lenoir <julien.lenoir@intel.com>
fit_print_contents prints similar fit information as printed in bootm stages.
Removing this API reduces redundancy & provides improvement in boottime.
Signed-off-by: Ravik Hasija <rahasij@linux.microsoft.com>
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this fairly uncommon header out of the common header.
We should not be using typedefs and these make it harder to use
forward declarations (to reduce header file inclusions). Drop the typedef.
These three globals relate to image handling. Move them to the image
header file.
These global variables are quite short and generic. In fact the same name
is more often used locally for struct members and function arguments.
Add a image_ prefix to make them easier to distinguish.
These functions are CPU-related and do not use driver model. Move them to
cpu_func.h
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with
allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line
with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of
cmd/ switch to using CONFIG_IS_ENABLED() to test what is set.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We only need the function found in cmd/disk.c when we have IDE, SCSI or
USB_STORAGE enabled. While the first two are easy to get right, in the
3rd case we assume that the set of cases where we do have USB and do not
enable USB_STORAGE are small enough that we can take the small bloat of
un-discarded strings on gcc prior to 6.x
If serial support is not compiled into U-Boot, which may be the case
for some SPL builds, the following warning will be generated in disk.c:
cmd/disk.c: In function 'common_diskboot':
cmd/disk.c:16:6: warning: variable 'dev' set but not used [-Wunused-but-set-variable]
int dev, part;
The warning is a result of printf() calls being optimized away, and
thus the whole dev variable becomes indeed unused. Mark the variable
as __maybe_unused .
This option currently enables both the command and the SCSI functionality.
Rename the existing option to CONFIG_SCSI since most of the code relates
to the feature.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
To ease conversion to driver model, add helper functions which deal with
calling each block device method. With driver model we can reimplement these
functions with the same arguments.
Use inline functions to avoid increasing code size on some boards.
This is a device number, and we want to use 'dev' to mean a driver model
device. Rename the member.
Rename this function to blk_get_device_part_str(). This is a better name
because it makes it clear that the function returns a block device and
parses a string.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
