path: root/cmd/date.c
2021-08-30Convert CONFIG_SYS_I2C_LEGACY to Kconfig and add CONFIG_[ST]PL_SYS_I2C_LEGACYTom Rini
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot have SYS_I2C_LEGACY and DM_I2C at the same time, introduce CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only in SPL. Finally, for some PowerPC cases we also need CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to one or more symbols. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-08-06cmd: date: rtc: Update command to read the first RTC with seq 0Michal Simek
RTCs are using sequence number defined in aliases node. Date command with DM_RTC enabled is looking for the first RTC with index 0. But when RTC_EMULATION is enabled it gets likely most of the time index 0 even when system has rtc0 device via aliases node and gets sequence number 0. That's why extend the code to look for sequence 0 number first. If this fails continue to use existing device with index 0. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2021-07-28i2c: Rename CONFIG_SYS_I2C to CONFIG_SYS_I2C_LEGACYSimon Glass
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less than a year away. Also we want to have a CONFIG_I2C for U-Boot proper just like we have CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules. Rename this symbol so it is clear it is going away. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-02-19cmd: date: Do not overwrite argumentsRoman Kapl
Arguments are const and belong to the caller. Calling date in a hush loop will yield different results from the second invocation. Signed-off-by: Roman Kapl <rka@sysgo.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
