path: root/cmd/cramfs.c
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move the image globals into image.hSimon Glass
These three globals relate to image handling. Move them to the image header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17image: Rename load_addr, save_addr, save_sizeSimon Glass
These global variables are quite short and generic. In fact the same name is more often used locally for struct members and function arguments. Add a image_ prefix to make them easier to distinguish. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22fs: Kconfig: Add a separate option for FS_JFFS2Simon Glass
Rather than using CMD_JFFS2 for both the filesystem and its command, we should have a separate option for each. This allows us to enable JFFS2 support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-18cmd: cramfs: use map_sysmem for sandbox supportTyler Hall
As with most other commands, this needs to factor in the sysmem offset in the sandbox or it will try to dereference the simulated physical address directly. Signed-off-by: Tyler Hall <tylerwhall@gmail.com>
2016-03-14Drop CONFIG_CRAMFS_CMDLINESimon Glass
This option doesn't do anything. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
