At present various drivers etc. access the device's 'seq' member directly.
This makes it harder to change the meaning of that member. Change access
to go through a function instead.
The drivers/i2c/lpc32xx_i2c.c file is left unchanged for now.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Use uclass_first_device and uclass_next_device in order to avoid exceptions
for drivers that aren't probed when cpu ops are requested.
Improve code style and fix indentations.
Fix incorrect line break when cpu info is not available.
Remove unneeded brackets.
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Commit 740d5d3 added two new features but only one feature name,
which results in NULL prints when device_id feature is selected.
Before:
HG556a # cpu detail
-1: cpu@0 BCM6358A1
ID = 0, freq = 300 MHz: L1 cache, MMU, NULL
Device ID 0x2a010
-1: cpu@1 BCM6358A1
ID = 1, freq = 300 MHz: L1 cache, MMU, NULL
Device ID 0x2a010
After:
HG556a # cpu detail
-1: cpu@0 BCM6358A1
ID = 0, freq = 300 MHz: L1 cache, MMU, Device ID
Device ID 0x2a010
-1: cpu@1 BCM6358A1
ID = 1, freq = 300 MHz: L1 cache, MMU, Device ID
Device ID 0x2a010
Some CPUs use microcode and each core can have a different version of
microcode loaded. Also some CPUs support the concept of an integer ID used
for identification purposes. Add support for these in the CPU uclass.
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
