path: root/cmd/cbfs.c
2021-08-02global: Convert simple_strtoul() with hex to hextoul()Simon Glass
It is a pain to have to specify the value 16 in each call. Add a new hextoul() function and update the code to use it. Add a proper comment to simple_strtoul() while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-27cbfs: Return the error code from file_cbfs_init()Simon Glass
We may as well return the error code and use it directly in the command code. CBFS still uses its own error enum which we may be able to remove, but leave it for now. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-18cbfs: Move result variable into the structSimon Glass
Move the result variable into the struct also, so that it can be used when BSS is not available. Add a function to read it. Note that all functions sill use the BSS version of the data. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-12-31fs: cbfs: Add missing standard CBFS component typesBin Meng
Current CBFS component type list is incomplete. Add missing ones. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-31fs: cbfs: Make all CBFS_TYPE_xxx macros consistentBin Meng
At present there are 2 macros that are named as CBFS_COMPONENT_xxx. Change them to CBFS_TYPE_xxx for consistency. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-03-31cmd: cbfs: fix reading the end_of_rom pointer for 64bit archsAndre Heider
The cast breaks the pointer on 64bit archs, so lets get rid of it. Signed-off-by: Andre Heider <a.heider@gmail.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-22cbfs: Update a function to be staticSimon Glass
All command functions should be static. Update the CBFS functions to follow this rule. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14dm: cbfs: Fix handling of invalid typeSimon Glass
The comment for file_cbfs_type() says that it returns 0 for an invalid type. The code appears to check for -1, except that it uses an unsigned variable to store the type. This results in a warning on 64-bit machines. Adjust it to make the meaning clearer. Continue to handle the -1 case since it may be needed. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
