path: root/cmd/cache.c
2019-12-02common: Move some cache and MMU functions out of common.hSimon Glass
These functions belong in cpu_func.h. Another option would be cache.h but that code uses driver model and we have not moved these cache functions to use driver model. Since they are CPU-related it seems reasonable to put them here. Move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-07-29Add validation for icache/dcache arguments - arguments different from ↵Eric Perie
off/on/flush are currently silently ignored. Signed-off-by: Eric Perie <eric.perie@yahoo.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
