To support the trust boot chain, we integrate the authentication
into the kernel image loading process. The kernel image will be verified
at its load address. So when signing the kernel image, we need to
use this load address which may change on different platforms.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 3c118b8d6bbe1a25ca8c8bafeb528309f16fc73d)
(cherry picked from commit fd9a9759ed9b3a9fc26b18aff00880382213b1ca)
In commit c2e7e72, the ramdisk relocation code was moved from
image_setup_linux to do_bootm, leaving the bootz and booti cases broken.
This patch fixes both by adding the BOOTM_STATE_RAMDISK state in their
call to do_bootm_states if CONFIG_SYS_BOOT_RAMDISK_HIGH is set.
Signed-off-by: Cédric Schieli <cschieli@gmail.com>
Reviewed-by: Rick Altherr <raltherr@google.com>
Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
The bootz and booti commands rely on common functionality that is found
in common/bootm.c and common/bootm_os.c. They do not however rely on
the rest of cmd/bootm.c to be implemented so split them into their own
files. Have various Makefiles include the required infrastructure for
CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration
of 'images' over to common/bootm.c.
