path: root/cmd/bootm.c
2016-10-31Fix spelling of "extended".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-20cmd: Split 'bootz' and 'booti' out from 'bootm'Tom Rini
The bootz and booti commands rely on common functionality that is found in common/bootm.c and common/bootm_os.c. They do not however rely on the rest of cmd/bootm.c to be implemented so split them into their own files. Have various Makefiles include the required infrastructure for CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration of 'images' over to common/bootm.c. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-24common: image: minimal android image iminfo supportMichael Trimarchi
We already support iminfo for other images. The idea of this patch is start to have a minimal support for android image format. We still need to print id[] array Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-06-03mtd: nand: Remove nand_info_t typedefScott Wood
This typedef serves no purpose other than causing confusion with struct nand_chip. Signed-off-by: Scott Wood <oss@buserror.net>
2016-05-25arm64: fix arm64 Linux boot image header field sizesAndre Przywara
The arm64 Linux boot protocol [1] describes the fields in the Image header as being 64-bit little endian values. So fix the endianess conversion to use 64-bit sized operations, for both image_size and text_offset. Also we use a local variable for the image_size to avoid both writing to the header and also accessing it after we actually unmapped it. Signed-off-by: Andre Przywara <andre.przywara@arm.com> [1] https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/arm64/booting.txt
2016-04-01arm64: booti: add missing unmap_sysmem()Masahiro Yamada
Make sure to call unmap_sysmem() for address allocated by map_sysmem() before leaving the function; however this patch gives no impact on the behavior because map_sysmem()/unmap_sysmem() does nothing except on Sandbox. Sandbox never runs this code because "booti" is a command for booting ARM64 kernel image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-24booti: Help text rework.Karsten Merker
Fix spelling errors in the "booti" help text and bring it more in line with the bootm/bootz help texts. Signed-off-by: Karsten Merker <merker@debian.org>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
