Enable HAB for imx8m Android Things platform, this will enable
HAB verify for bootloader.img(atf+tee+u-boot) at spl stage.
Disable the HAB verify for bootimg because we will use AVB to
verify it.
Test: Build and boot ok on AIY.
Change-Id: Ia6ee456c7c5fa71afc3740689adf898f411c6c4e
Signed-off-by: Ji Luo <ji.luo@nxp.com>
When secure boot is enabled, add authenticate_image in booti to authenticate
kernel image.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit f29a143cdb8c74566113737e9be7e1bcd8c625f4)
With commit 6808ef9ac2a6 ("move booti_setup to arch/arm/lig/image.c"),
images->ep has not been set at this point.
Fixes: 6808ef9ac2a6 ("move booti_setup to arch/arm/lig/image.c")
Reviewed-by: Bin Chen <bin.chen@linaro.org>
Follow bootz's pattern by moving the booti_setup to arch/arm/lib.
This allows to use booti_setup in other paths, e.g booting
an Android image containing Image format.
Note that kernel relocation is move out of booti_setup and it is the
caller's responsibility to do it and allows them do it differently. say,
cmd/booti.c just do a manually, while in the bootm path, we can use
bootm_load_os(with some changes).
Signed-off-by: Bin Chen <bin.chen@linaro.org>
At first, the ARM64 Linux booting requirement recommended that the
kernel image be placed text_offset bytes from 2MB aligned base near
the start of usable system RAM because memory below that base address
was unusable at that time.
This requirement was relaxed by Linux commit a7f8de168ace ("arm64:
allow kernel Image to be loaded anywhere in physical memory").
Since then, the bit 3 of the flags field indicates the tolerance
of the kernel physical placement. If this bit is set, the 2MB
aligned base may be anywhere in physical memory. For details, see
Documentation/arm64/booting.txt of Linux.
The booti command should be also relaxed. If the bit 3 is set,
images->ep is respected, and the image is placed at the nearest
bootable location. Otherwise, it is relocated to the start of the
system RAM to keep the original behavior.
Another wrinkle we need to take care of is the unknown endianness of
text_offset for a kernel older than commit a2c1d73b94ed (i.e. v3.16).
We can detect this based on the image_size field. If the field is
zero, just use a fixed offset 0x80000.
Commit ec6617c39741adc6c549 ("armv8: Support loading 32-bit OS in AArch32
execution state") broke SMP boot by assuming that an image is 32-bit if
the arch field in the spin table != IH_ARCH_DEFAULT (i.e.
IH_ARCH_ARM64), even if the arch field also does not match IH_ARCH_ARM,
even though nothing actually set the arch field in the spin table.
Commit e2c18e40b111470f ("armv8: fsl-layerscape: SMP support for loading
32-bit OS") fixed this for bootm by setting the arch field of the spin
table based on images.os.arch, but booti remaineed broken because it did
not set images.os.arch.
Fixes: ec6617c39741adc6c549 ("armv8: Support loading 32-bit OS in AArch32 execution state")
Fixes: e2c18e40b111 ("armv8: fsl-layerscape: SMP support for loading 32-bit OS")
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Chenhui Zhao <chenhui.zhao@nxp.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Stuart Yoder <stuart.yoder@nxp.com>
Signed-off-by: Scott Wood <oss@buserror.net>
In commit c2e7e72, the ramdisk relocation code was moved from
image_setup_linux to do_bootm, leaving the bootz and booti cases broken.
This patch fixes both by adding the BOOTM_STATE_RAMDISK state in their
call to do_bootm_states if CONFIG_SYS_BOOT_RAMDISK_HIGH is set.
Signed-off-by: Cédric Schieli <cschieli@gmail.com>
Reviewed-by: Rick Altherr <raltherr@google.com>
Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
The bootz and booti commands rely on common functionality that is found
in common/bootm.c and common/bootm_os.c. They do not however rely on
the rest of cmd/bootm.c to be implemented so split them into their own
files. Have various Makefiles include the required infrastructure for
CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration
of 'images' over to common/bootm.c.
