path: root/cmd/bmp.c
2019-02-15cmd: bmp: Make integer-to-pointer cast platform, independentAdam Heinrich
This patch fixes the int-to-pointer-cast warning on aarch64. Signed-off-by: Adam Heinrich <adam@adamh.cz> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2018-12-04cmd: bmp: manage centered displayPatrick Delaunay
Allow to display BMP at the middle of the screen. 'm' means "middle" as it is done for the splashscreen variable: splashpos=m,m Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2016-03-14dm: Use uclass_first_device_err() where it is usefulSimon Glass
Use this new function in places where it simplifies the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-06cmd: Fix control bmp_display()Simon Glass
All paths should share the same return. Reported-by: Coverity (CID:134903) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
