path: root/cmd/bind.c
2018-08-21cmd: Add bind/unbind commands to bind a device to a driver from the command lineJean-Jacques Hiblot
In some cases it can be useful to be able to bind a device to a driver from the command line. The obvious example is for versatile devices such as USB gadget. Another use case is when the devices are not yet ready at startup and require some setup before the drivers are bound (ex: FPGA which bitsream is fetched from a mass storage or ethernet) usage example: bind usb_dev_generic 0 usb_ether unbind usb_dev_generic 0 usb_ether or unbind eth 1 bind /ocp/omap_dwc3@48380000/usb@48390000 usb_ether unbind /ocp/omap_dwc3@48380000/usb@48390000 Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
