path: root/cmd/bdinfo.c
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-11-16cmd/bdinfo: correct output of numerical valuesHeinrich Schuchardt
Display all digits on 64bit systems. Currently we print only the lower 32 bits. Examples of values that can exceed 32 bits are the size and start of memory banks. For fdt_blob use the same output method as for other values. This avoids misalignment. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-10-03riscv: cmd: bdinfo: Print the relocation addressBin Meng
Add printing of U-Boot relocation address. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-10-03riscv: Remove mach typeBin Meng
Since the mach_id is not used by RISC-V, remove it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-04-06powerpc: mpc8xx: Change CONFIG_8xx to CONFIG_MPC8xxChristophe Leroy
CONFIG_8xx doesn't mean much outside of arch/powerpc/ This patch renames it CONFIG_MPC8xx just like CONFIG_MPC85xx etc ... It also renames 8xx_immap.h to immap_8xx.h to be consistent with other file names. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-01-30cmd/bdinfo: print relocation info on X86Heinrich Schuchardt
For debugging U-Boot in qemu-x86 the relocation address is needed. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-12riscv: Modify generic codes to support RISC-VRick Chen
Support common commands bdinfo and image format, also modify common generic flow for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13cmd/bdinfo: correct comment in board_detailChris Packham
This appears to be a simple typo that dates back to the original implementation of board_detail in commit e79394643b26 ("common: Update cmd_bdinfo for PPC"). Signed-off-by: Chris Packham <judge.packham@gmail.com>
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-23bdinfo: print fdt_blobHeiko Schocher
for debugging it is handy to know the fdt_blob address. So print it in bdinfo. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-06-12powerpc, 5xx: remove support for 5xxHeiko Schocher
There was for long time no activity in the 5xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 5xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-05-12cmd/bdinfo.c: Fix unused function warningTom Rini
On most architectures we do not call print_std_bdinfo() so mark it with __maybe_unused. Reported by clang-3.8. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05OpenRISC: RemoveTom Rini
The OpenRISC architecture is currently unmaintained, remove. Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-14armv8: Add global variable resv_ramYork Sun
Use gd->arch.resv_ram to track reserved memory allocation. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-16x86: bdinfo: Drop meaningless valuesSimon Glass
These are not useful on x86 so do not print them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16bdinfo: Don't print out empty DRAM banksSimon Glass
There is no sense in printing out DRAM banks of size 0 since this means they are empty. Skip them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-15xtensa: add support for the xtensa processor architecture [1/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Cadence. This is the first part of the basic architecture port with changes to common files. The 'arch/xtensa' directory, and boards and additional drivers will be in separate commits. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-05cmd/bdinfo: extract print_std_bdinfoMax Filippov
print_std_bdinfo outputs typical set of board information entries: boot params location, memory and flash addresses and sizes, network interfaces information and configured serial baud rate. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05cmd/bdinfo: extract print_baudrateMax Filippov
print_baudrate outputs serial baud rate. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05cmd/bdinfo: extract print_eth_ip_addrMax Filippov
print_eth_ip_addr outputs eth configurations for up to 6 interfaces and configured IP address. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-05cmd/bdinfo: extract print_bi_flashMax Filippov
print_bi_flash outputs flashstart, flashsize and flashoffset lines. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05cmd/bdinfo: extract print_bi_dramMax Filippov
print_bi_dram outputs start address and size for each DRAM bank. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05cmd/bdinfo: extract print_bi_memMax Filippov
print_bi_mem outputs memstart and memsize lines. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05cmd/bdinfo: extract print_bi_boot_paramsMax Filippov
print_bi_boot_params outputs boot parameters structure location. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-27arm: Show early-malloc() usage in bdinfoSimon Glass
This is useful information to show how close we are to the limit. At present it is only available by enabling DEBUG in board_r.c. Make it available with the 'bdinfo' command also. Note that this affects ARM only. The bdinfo command is different for each architecture. Rather than duplicating the code it would be better to refactor it (as was done with global_data). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-15armv8: Move secure_ram variable out of generic global dataYork Sun
Secure_ram variable was put in generic global data. But only ARMv8 uses this variable. Move it to ARM specific data structure. Signed-off-by: York Sun <york.sun@nxp.com>
2016-05-21mips: Report reloc information in bdinfoTim Chick
Signed-off-by: Tim Chick <tim.chick@mediatek.com>
2016-01-27microblaze: Do not print eth device when DM_ETH is enabledMichal Simek
Doing the same fix as is done for ARM by: "Avoid calling print_eths() with driver model" (sha1: ff97380015b6b5d7d6267417a1cd6fc0e67b81bc) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
