path: root/cmd/avb.c
2019-04-26avb: add support for named persistent valuesIgor Opaniuk
AVB 2.0 spec. revision 1.1 introduces support for named persistent values that must be tamper evident and allows AVB to store arbitrary key-value pairs [1]. Introduce implementation of two additional AVB operations read_persistent_value()/write_persistent_value() for retrieving/storing named persistent values. Correspondent pull request in the OP-TEE OS project repo [2]. [1]: https://android.googlesource.com/platform/external/avb/+/android-9.0.0_r22 [2]: https://github.com/OP-TEE/optee_os/pull/2699 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org> Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
2018-10-07cmd: avb: print error message if command failsJens Wiklander
Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-10-07cmd: avb read_rb: print rb_idx in hexadecimalJens Wiklander
Prior to this patch was do_avb_write_rb() reading supplied rb_idx as a hexadecimal number while do_avb_read_rb() printed the read out rb_idx as decimal number. For consistency change do_avb_read_rb() to print rb_idx as a hexadecimal number too. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Igor Opaniuk <igor.opaniuk@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-06-18avb2.0: add boot states and dm-verity supportIgor Opaniuk
1. Add initial support of boot states mode (red, green, yellow) 2. Add functions for enforcing dm-verity configurations Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org>
2018-06-18cmd: avb2.0: avb command for performing verificationIgor Opaniuk
Enable a "avb" command to execute Android Verified Boot 2.0 operations. It includes such subcommands: avb init - initialize avb2 subsystem avb read_rb - read rollback index avb write_rb - write rollback index avb is_unlocked - check device lock state avb get_uuid - read and print uuid of a partition avb read_part - read data from partition avb read_part_hex - read data from partition and output to stdout avb write_part - write data to partition avb verify - run full verification chain Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org>
