path: root/cmd/aes.c
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-29aes: Allow non-zero initialization vectorАндрей Мозжухин
AES encryption in CBC mode, in most cases, must be used with random initialization vector. Using the same key and initialization vector several times is weak and must be avoided. Added iv parameter to the aes_cbc_encrypt_blocks and aes_cbc_decrypt_blocks functions for passing initialization vector. Command 'aes' now also require the initialization vector parameter. Signed-off-by: Andrey Mozzhuhin <amozzhuhin@yandex.ru>
2017-04-12Rename aes.h to uboot_aes.hStefano Babic
aes.h is a too generic name if this file can be exported and used by a program. Rename it to avoid any conflicts with other files (for example, from openSSL). Signed-off-by: Stefano Babic <sbabic@denx.de>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
