Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Add support for mvebu bubt command for flash image
load, check and burn on boot device.
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Neta Zur Hershkovits <neta@marvell.com>
Cc: Omri Itach <omrii@marvell.com>
Cc: Igal Liberman <igall@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Cc: Hanna Hawa <hannah@marvell.com>
Move crosec commands from drivers/misc/cros_ec.c to
cmd/cros_ec.c
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Miao Yan <yanmiaobest@gmail.com>
Cc: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: u-boot@lists.denx.de
We only need the function found in cmd/disk.c when we have IDE, SCSI or
USB_STORAGE enabled. While the first two are easy to get right, in the
3rd case we assume that the set of cases where we do have USB and do not
enable USB_STORAGE are small enough that we can take the small bloat of
un-discarded strings on gcc prior to 6.x
The bootz and booti commands rely on common functionality that is found
in common/bootm.c and common/bootm_os.c. They do not however rely on
the rest of cmd/bootm.c to be implemented so split them into their own
files. Have various Makefiles include the required infrastructure for
CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration
of 'images' over to common/bootm.c.
There is no more define of CONFIG_SYS_HUSH_PARSER. Rename some
remaining references and drop the backward compatible Kconfig entry.
Make file names consistent with CONFIG_QFW and CONFIG_CMD_QFW
Signed-off-by: Miao Yan <yanmiaobest@gmail.com>
This patch splits qfw command interface and qfw core function into two
files, and introduces a new Kconfig option (CONFIG_QFW) for qfw core.
Now when qfw command interface is enabled, it will automatically select
qfw core. This patch also makes the ACPI table generation select
CONFIG_QFW.
- Move the command portion of arch/x86/cpu/qemu/fw_cfg.c into
cmd/qemu_fw_cfg.c
- Move arch/x86/include/asm/fw_cfg.h to include/qemu_fw_cfg.h
- Rename ACPI table portion to arch/x86/cpu/qemu/acpi_table.c
At present the SCSI command code includes both the command-processing code
and the core SCSI functions and data structures.
Separate the latter into its own file, adding functions as needed to avoid
the command code accessing data structures directly. This functions use the
new legacy block functions.
With this commit:
- There is no CONFIG option referenced from the command code
- The concept of a 'current SCSI device' is confined to the command code
This will make it easier to convert this code to driver model.
This option currently enables both the command and the SCSI functionality.
Rename the existing option to CONFIG_SCSI since most of the code relates
to the feature.
Create CMD_FDT Kconfig entry to have an option to disable fdt command
which is not required for small configuration which requires libfdt
only.
Enable it by default for all targets which enables OF_LIBFDT.
[trini: Fixup flea3/sandbox/id8313/siemens-am33xx/smartweb]
Add a block device cache to speed up repeated reads of block devices by
various filesystems.
This small amount of cache can dramatically speed up filesystem
operations by skipping repeated reads of common areas of a block
device (typically directory structures).
This has shown to have some benefit on FAT filesystem operations of
loading a kernel and RAM disk, but more dramatic benefits on ext4
filesystems when the kernel and/or RAM disk are spread across
multiple extent header structures as described in commit fc0fc50.
The cache is implemented through a minimal list (block_cache) maintained
in most-recently-used order and count of the current number of entries
(cache_count). It uses a maximum block count setting to prevent copies
of large block reads and an upper bound on the number of cached areas.
The maximum number of entries in the cache defaults to 32 and the maximum
number of blocks per cache entry has a default of 2, which has shown to
produce the best results on testing of ext4 and FAT filesystems.
The 'blkcache' command (enabled through CONFIG_CMD_BLOCK_CACHE) allows
changing these values and can be used to tune for a particular filesystem
layout.
Signed-off-by: Eric Nelson <eric@nelint.com>
In order to execute an EFI application, we need to bridge the gap between
U-Boot's notion of executing images and EFI's notion of doing the same.
The best path forward IMHO here is to stick completely to the way U-Boot
deals with payloads. You manually load them using whatever method to RAM
and then have a simple boot command to execute them. So in our case, you
would do
# load mmc 0:1 $loadaddr grub.efi
# bootefi $loadaddr
which then gets you into a grub shell. Fdt information known to U-boot
via the fdt addr command is also passed to the EFI payload.
[trini: Guard help text with CONFIG_SYS_LONGHELP]
Now that they are in their own directory, we can remove this prefix.
This makes it easier to find a file since the prefix does not get in the
way.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
There are a lot of unrelated files in common, including all of the commands.
Moving them into their own directory makes them easier to find and is more
logical.
Some commands include non-command code, such as cmd_scsi.c. This should be
sorted out at some point so that the function can be enabled with or without
the associated command.
Unfortunately, with m68k I get this error:
m68k: + M5329AFEE
+arch/m68k/cpu/mcf532x/start.o: In function `_start':
+arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o
I hope someone can shed some light on what this means. I hope it isn't
depending on the position of code in the image.
