path: root/cmd/Kconfig
2019-06-13Kconfig: Add SPI / SPI_FLASH as dependenciesTom Rini
In order to use CMD_SF / CMD_SPI / ENV_IS_IN_SPI_FLASH we need to have the SPI (or SPI_FLASH/DM_SPI_FLASH, for CMD_SF) enabled. Express this in the Kconfigs. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-05-28cmd: remove unused `display` commandHeinrich Schuchardt
Compiling the display command leads to an error undefined reference to `display_set' No implementation of display_set() exists in U-Boot. Eliminate the `display` command as well as the accompanying files. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-12efi_loader: make device path to text protocol customizableHeinrich Schuchardt
The device path to text protocol is not needed for EBBR compliance. So let's make it a customizable option. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-10cmd: ubifs: Remove select for non-existent optionChris Packham
There is no 'config CRC32', remove the select that was attempting to use it. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-05-09RISCV: image: Add booti supportAtish Patra
This patch adds booti support for RISC-V Linux kernel. The existing bootm method will also continue to work as it is. It depends on the following kernel patch which adds the header to the flat Image. Gzip compressed Image (Image.gz) support is not enabled with this patch. https://patchwork.kernel.org/patch/10925543/ Tested on HiFive Unleashed and QEMU. Signed-off-by: Atish Patra <atish.patra@wdc.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Karsten Merker <merker@debian.org> Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
2019-04-26Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2019-04-25Revert "cmd: Kconfig: Do not include EEPROM if DM_I2C is used without ↵Simon Goldschmidt
DM_I2C_COMPAT" This reverts commit 65a97e7fcf54feb7c4ebe1aee8a572830af4cf51. The 'eeprom' command has been converted to work with DM_I2C in a patch submitted around the same time as this commit: commit 0c07a9b4078d ("eeprom: Add device model based I2C support to eeprom command") Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-04-24Merge tag 'pull-24apr19' of git://git.denx.de/u-boot-dmTom Rini
Various minor sandbox iumprovements Fixes for tracing with sandbox Refactoring for boot_get_fdt()
2019-04-23Convert CONFIG_TRACE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_TRACE Signed-off-by: Simon Glass <sjg@chromium.org>
2019-04-23common: command: Add command execution tracer.Christoph Muellner
When using boot scripts it can become quite hard to understand which commands are actually executed during bootup (e.g. where is a kernel image loaded from or which DTB is in use). Shell scripts suffer from a similar problem and many shells address this problem with a command execution tracer (e.g. BASH has xtrace, which can be enabled by "set -x"). This patch introduces a command tracer for U-Boot, which prints every command with its arguments before it is executed. Signed-off-by: Christoph Muellner <christoph.muellner@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-04-22cmd: add exception commandHeinrich Schuchardt
The 'exception' command allows to test exception handling. This implementation supports ARM, x86, RISC-V and the following exceptions: * 'breakpoint' - prefetch abort exception (ARM 32bit only) * 'unaligned' - data abort exception (ARM only) * 'undefined' - undefined instruction exception Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-12cmd: add wdt commandMichael Walle
Add a command to control the watchdog devices. This is useful if the watchdog is rather long running (eg. seconds) and it should be controlled by scripts. It is also handy during debugging. Signed-off-by: Michael Walle <michael@walle.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-25Convert CONFIG_DEFAULT_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_DEFAULT_SPI_BUS CONFIG_DEFAULT_SPI_MODE Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-25cmd: add efidebug commandAKASHI Takahiro
Currently, there is no easy way to add or modify UEFI variables. In particular, bootmgr supports BootOrder/BootXXXX variables, it is quite hard to define them as u-boot variables because they are represented in a complicated and encoded format. The new command, efidebug, helps address these issues and give us more friendly interfaces: * efidebug boot add: add BootXXXX variable * efidebug boot rm: remove BootXXXX variable * efidebug boot dump: display all BootXXXX variables * efidebug boot next: set BootNext variable * efidebug boot order: set/display a boot order (BootOrder) Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-25cmd: env: add "-e" option for handling UEFI variablesAKASHI Takahiro
"env [print|set] -e" allows for handling uefi variables without knowing details about mapping to corresponding u-boot variables. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-22cmd: Kconfig: LED command depends on LED subsystemsJan Kiszka
Without CONFIG_LED, we get cmd/built-in.o: In function `show_led_state': cmd/led.c:40: undefined reference to `led_get_state' cmd/built-in.o: In function `do_led': cmd/led.c:99: undefined reference to `led_get_by_label' cmd/led.c:108: undefined reference to `led_set_state' Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
2019-02-13efi_loader: CMD_BOOTEFI_HELLO_COMPILE in configsHeinrich Schuchardt
It should not be necessary to adjust CMD_BOOTEFI_HELLO_COMPILE in config files. arch/arm/lib/crt0_arm_efi.S cannot be compiled in thumbs mode. We can disable CMD_BOOTEFI_HELLO_COMPILE for CONFIG_CPU_V7M. So there is no longer a need to disable it in stm32 configs. helloworld.efi can be built without problems on x86_64. So there is no need to disable it in chromebook_link64_defconfig and qemu-x86_64_defconfig. Same is true for ARM V7A. So do not disable CMD_BOOTEFI_HELLO_COMPILE in kp_imx6q_tpc_defconfig. Some architecture checks are already make for EFI_LOADER. There is no need to repeat them for CMD_BOOTEFI_HELLO_COMPILE Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice.Chotard@st.com Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-10cmd: Kconfig: Do not include EEPROM if DM_I2C is used without DM_I2C_COMPATJean-Jacques Hiblot
The implementation of the EEPROM commands does not support the DM I2C API. Prevent compilation breakage by not enabling it if the non-DM API is not available (if DM_I2C is used without DM_I2C_COMPAT) Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-12-04cmd: add clear screen 'cls' commandAnatolij Gustschin
Add common clear screen command for configurations CONFIG_DM_VIDEO, CONFIG_LCD and CONFIG_CFB_CONSOLE. Remove the existing cls command implementation from lcd.c code and activate the command for all boards enabling CONFIG_LCD for compatibility reasons. Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Patrick.Delaunay <patrick.delaunay@free.fr>
2018-11-16cmd: pinmux: Add pinmux commandPatrice Chotard
pinmux command allows to : - list all pin-controllers available on platforms - select a pin-controller - display the muxing of all pins of the current pin-controller or all pin-controllers depending of given options Signed-off-by: Patrice Chotard <patrice.chotard@st.com> cmd: pinmux: Fix pinmux command if "pinmux status" command is used without having set dev using "pinmux dev", print pinmux usage Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14virtio: cmd: Add virtio command for virtio devicesTuomas Tynkkynen
Add 'virtio' command in U-Boot command line. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-13cmd: ubi: Remove useless call to mtdparts_init()Boris Brezillon
Commit c58fb2cdb3e4 ("cmd: ubi: clean the partition handling") introduced a call to mtd_probe_devices() in the ubi_attach() path and this function takes care of parsing mtdparts/mtdids and creating/registering the associated mtd partitions. The mtdparts_init() call in the ubi_detach() path is not only unnecessary but can sometimes print error messages even when things work properly (that's the case with SPI NAND devices that have not been probed with 'mtd list'), which is misleading. Remove this call to mtdparts_init() and drop the dependency on CMD_MTDPARTS. Fixes: c58fb2cdb3e4 ("cmd: ubi: clean the partition handling") Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Tested-by: Stefan Roese <sr@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-11-13mtd: Make {MTDIDS, MTDPARTS}_DEFAULT visible when MTD_PARTITIONS is selectedBoris Brezillon
gwventana configs are relying on CMD_UBI to select CMD_MTDPARTS, which is then making {MTDIDS,MTDPARTS}_DEFAULT options available. We are about to remove the 'select CMD_MTDPARTS' statement in the CMD_UBI entry, but if we do that without first making sure {MTDIDS,MTDPARTS}_DEFAULT are visible, we end up with a build failure when building gwventana configs. Address that by adding a depends on MTD_PARTITIONS to {MTDIDS,MTDPARTS}_DEFAULT which does the trick since CMD_UBI selects MTD_UBI which in turn selects MTD_PARTITIONS. We also get rid of the depends on CMD_MTD, since CMD_MTD also selects MTD_PARTITIONS. Reported-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-10-16cmd: kgdb: Enable kgdb only for PPCMichal Simek
Only PPC supports this option that's why there should be proper dependency setup via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-02cmd: mtdparts: describe as legacyMiquel Raynal
The 'mtdparts' command is not needed anymore. While the environment variable is still valid (and useful, along with the 'mtdids' one), the command has been replaced by 'mtd' which is much more close to the MTD stack and do not add its own specific glue. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2018-10-02cmd: ubi: clean the partition handlingMiquel Raynal
UBI should not mess with MTD partitions, now that the partitions are handled in a clean way, clean the ubi command and avoid using this uneeded extra-glue to reference the devices. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2018-10-02cmd: mtd: add 'mtd' commandMiquel Raynal
There should not be a 'nand' command, a 'sf' command and certainly not a new 'spi-nand' command. Write a 'mtd' command instead to manage all MTD devices/partitions at once. This should be the preferred way to access any MTD device. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2018-09-29Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-09-29cmd: Relocate poweroff under Device access commandsAdam Ford
Previously poweroff was located under boot. It seems to make more sense to have it located under the Device access commands. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-28w1: add command for onewire protocolEugen Hristev
Add basic command for bus information and read for onewire bus using Dallas 1-Wire protocol. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28cmd: Add osd commandsMario Six
Add command to query information from and write text to on-screen display (OSD) devices. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-25cmd: add conitrace commandHeinrich Schuchardt
The 'conitrace' command prints the codes received from the console input as hexadecimal numbers. This developer utility is useful for testing the handling of special keys by keyboard drivers. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-08-26cmd: ubi: change 'default y' for SUNXI to 'imply' in KconfigMasahiro Yamada
It is not preferred to put SUNXI-specific code in the common place. Change it to 'imply' property of ARCH_SUNXI. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-08-24Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2018-08-21cmd: Add bind/unbind commands to bind a device to a driver from the command lineJean-Jacques Hiblot
In some cases it can be useful to be able to bind a device to a driver from the command line. The obvious example is for versatile devices such as USB gadget. Another use case is when the devices are not yet ready at startup and require some setup before the drivers are bound (ex: FPGA which bitsream is fetched from a mass storage or ethernet) usage example: bind usb_dev_generic 0 usb_ether unbind usb_dev_generic 0 usb_ether or unbind eth 1 bind /ocp/omap_dwc3@48380000/usb@48390000 usb_ether unbind /ocp/omap_dwc3@48380000/usb@48390000 Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-08-20cmd: Add dtimg commandSam Protsenko
dtimg command allows user to work with Android DTB/DTBO image format. Such as, getting the address of desired DTB/DTBO file, printing the dump of the image in U-Boot shell, etc. This command is needed to provide Android boot with new Android DT image format further. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-08-11cmd: Add axi commandMario Six
Add a command to debug the AXI bus. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-07-30tpmv2: Make it select CMD_LOGTom Rini
The TPMv2 code requires the log functionality, so select it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-30dm: Change CMD_DM enablingMichal Simek
CMD_DM is used for debug purpose and it shouldn't be enabled by default via Kconfig. Unfortunately this is in the tree for quite a long time that's why solution is to use imply DM for all targets which are enabling DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-30Kconfig: Sort bool, default, select and imply optionsMichal Simek
Fix Kconfig bool, default, select and imply options to be alphabetically sorted. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-07-30Kconfig: Replace spaces with tabs and missing newlineMichal Simek
Trivial Kconfig cleanup. Use tabs instead of spaces and every Kconfig entry should be separated by newline. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-24avb2.0: add proper dependenciesIgor Opaniuk
1. Since libavb library alone is highly portable, introduce dedicated Kconfig symbol for AVB bootloader-dependent operations, so it's possible to build libavb separately. AVB bootloader-dependent operations include: * Helpers to process strings in order to build OS bootargs. * Helpers to access MMC, similar to drivers/fastboot/fb_mmc.c. * Helpers to alloc/init/free avb ops. 2. Add CONFIG_FASTBOOT dependency, as fastboot buffer is re-used in partition verification operations. Reported-by: Eugeniu Rosca <rosca.eugeniu@gmail.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org> Reviewed-by: Eugeniu Rosca <rosca.eugeniu@gmail.com> Tested-by: Eugeniu Rosca <rosca.eugeniu@gmail.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-02net: Add option to prefer bootp/dhcp serveripAlexander Graf
Currently we can choose between 2 different types of behavior for the serverip variable: 1) Always overwrite it with the DHCP server IP address (default) 2) Ignore what the DHCP server says (CONFIG_BOOTP_SERVERIP) This patch adds a 3rd option: 3) Use serverip from DHCP if no serverip is given (CONFIG_BOOTP_PREFER_SERVERIP) With this new option, we can have the default case that a boot file gets loaded from the DHCP provided TFTP server work while allowing users to specify their own serverip variable to explicitly use a different tftp server. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-02net: Add new wol command - Wake on LANLothar Felten
Add a new command 'wol': Wait for an incoming Wake-on-LAN packet or time out if no WoL packed is received. If the WoL packet contains a password, it is saved in the environment variable 'wolpassword' using the etherwake format (dot or colon separated decimals). Intended use case: a networked device should boot an alternate image. It's attached to a network on a client site, modifying the DHCP server configuration or setup of a tftp server is not allowed. After power on the device waits a few seconds for a WoL packet. If a packet is received, the device boots the alternate image. Otherwise it boots the default image. This method is a simple way to interact with a system via network even if only the MAC address is known. Tools to send WoL packets are available on all common platforms. Some Ethernet drivers seem to pad the incoming packet. The additional padding bytes might be recognized as Wake-on-LAN password bytes. By default enabled in pengwyn_defconfig. Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-18cmd: avb2.0: avb command for performing verificationIgor Opaniuk
Enable a "avb" command to execute Android Verified Boot 2.0 operations. It includes such subcommands: avb init - initialize avb2 subsystem avb read_rb - read rollback index avb write_rb - write rollback index avb is_unlocked - check device lock state avb get_uuid - read and print uuid of a partition avb read_part - read data from partition avb read_part_hex - read data from partition and output to stdout avb write_part - write data to partition avb verify - run full verification chain Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org>
2018-06-13net: Express LINK_LOCAL dependency on LIB_RANDJoe Hershberger
