Put all informations about targets, including state (active or
orphan) and maintainers, in boards.cfg; remove MAINTAINERS;
adjust the build system accordingly.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
tools/Makefile
drivers/serial/serial.c
The conflict above was a trivial case of adding one init
function in each branch, and manually resolved in merge.
Arndale board is based on samsung's exynos5250 soc.
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org>
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
add support for the am335x based boards from siemens:
dxr2:
- DDR3 128MiB
- NAND 256MiB
- Ethernet with external Switch SMSC LAN9303
- no PMIC
- internal Watchdog
- DFU support
pxm2:
- DDR2 512 MiB
- NAND 1024 MiB
- PMIC
- PHY atheros ar803x
- USB Host
- internal Watchdog
- DFU support
rut:
- DDR3 256 MiB
- NAND 256 MiB
- PMIC
- PHY natsemi dp83630
- external Watchdog
- DFU support
Signed-off-by: Roger Meier <r.meier@siemens.com>
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
Cc: Pascal Bach <pascal.bach@siemens.com>
Cc: Tom Rini <trini@ti.com>
The target uses AUART 3 instead of the DUART for console output.
Signed-off-by: Andreas Wass <andreas.wass@dalelven.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
This board and especially the CPU (PPC405CR) is EOL.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Wolfgang Denk <wd@denx.de>
Fixup an easy conflict over adding the clk_get prototype and USB_OTG
defines for am33xx having moved.
arch/arm/include/asm/arch-am33xx/hardware.h
Signed-off-by: Antoine Tenart <atenart@adeneo-embedded.com>
[trini: Change to SPDX, fix a few compiler warnings, adapt to
CONFIG_OMAP_COMMON]
add the am1808 based ipam390 board from Barix.
- 128MByte, DDR2, synchronous RAM 16bit databus to SDRAM
interface
- 128MByte, NAND Flash, 8bit databus to the NANDFlash
Interface
- Ethernet PHY Micrel KSZ8051R via RMII
- Console on UART 0
- booting fron nand flash
- spl falcon bootmode
Add config file
C29XPCIE board is a series of Freescale PCIe add-in cards to perform
as public key crypto accelerator or secure key management module. It
includes C293PCIE board, C293PCIE board and C291PCIE board.
- 512KB platform SRAM in addition to 512K L2 Cache/SRAM
- 512MB soldered DDR3 32bit memory
- CPLD System Logic
- 64MB x16 NOR flash and 4GB x8 NAND flash
- 16MB SPI flash
Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com>
Singed-off-by: Po Liu <Po.Liu@freescale.com>
[yorksun: Fixup include/configs/C29XPCIE.h]
Signed-off-by: York Sun <yorksun@freescale.com>
Add new board p1020RDB-PD. P1020RDB-PD board was update from P1020RDB.
DDR changed from DDR2 1G to DDR3 2G.
NAND: 128 MiB
Flash: 64 MiB
Also change P1020RDB to P1020RDB-PC to distinguish from P1020RDB board.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
Acked-by: York Sun <yorksun@freescale.com>
Add emulator support for T4240. Emulator has limited peripherals and
interfaces. Difference between emulator and T4240QDS includes:
ECC for DDR is disabled due the procedure to load images
No board FPGA (QIXIS)
NOR flash has 32-bit port for higher loading speed
IFC and I2C timing don't really matter, so set them fast
No ethernet
TWR-P1025 Specification:
Memory subsystem:
512MB DDR3 (on board DDR)
64Mbyte 16bit NOR flash
One microSD Card slot
Ethernet:
eTSEC1: Connected to Atheros AR8035 GETH PHY
eTSEC3: Connected to Atheros AR8035 GETH PHY
UART:
Two UARTs are routed to the FDTI dual USB to RS232 convertor
USB: Two USB2.0 Type A ports
I2C:
AT24C01B 1K Board EEPROM (8 bit address)
QUICC Engine:
Connected to DP83849i PHY supply two 10/100M ethernet ports
QE UART for RS485 or RS232
PCIE:
One mini-PCIE slot
Signed-off-by: Michael Johnston <michael.johnston@freescale.com>
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
[yorksun: Fixup include/configs/p1_twr.h]
board/freescale/mx6qsabrelite/Makefile
board/freescale/mx6qsabrelite/mx6qsabrelite.c
include/configs/mx6qsabrelite.h
The BeagleBone Black differs from the other AM335x boards in a few
significant ways, so it makes sense to create a custom configuration
for it. In particular, it uses eMMC instead of NAND flash.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Give the user the ability to disable NAND support by defining
CONFIG_NO_NAND. This will allow custom hardware to easily support
this configuration.
[trini: Make apply on top of other series]
accessing a lan9303 switch with the cpsw driver results in wrong
speed detection, as the switch sets the BMSR_ERCAP in BMSR
register, and follow read of the MII_STAT1000 register fails, as
the switch does not support it. Current code did not check,
if a phy_read() fails ... fix this.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
NOR requires that s_init be within the first 4KiB of the image so that
we can perform the rest of the required pinmuxing to talk with the rest
of NOR that we are found on. When NOR_BOOT is set we save our
environment in NOR at 512KiB and a redundant copy at 768KiB. We avoid
using SPL for this case and u-boot.bin is written directly to the start
of NOR.
We enclose the DMM-related parts of arch/arm/cpu/armv7/am33xx/emif4.c
with TI81xx checks as at this time U-Boot does not discard unused
sections in the main build and this code relies on functions specific to
(and only provided in) ti81xx-related code.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
This patch adds support for the NOR module that attaches
to the memory cape for a Beaglebone board. This does not
add booting support; only support so that you can boot from
SD/MMC and see the NOR module so that it can be programmed.
[trini: Clean up config changes slightly]
mx6qsabrelite and nitrogen6q boards are hardware compatible, so let's avoid the
code duplication and only use the nitrogen6x source code to make board code
maintainance easier.
Tested booting a mainline device tree kernel on a mx6qsabrelite board.
Because the SOCFPGA platform will include support for Cyclone V and
Arria V FPGA parts, renaming socfpga_cyclone5 folder to socfpga to
be more generic.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Reviewed-by: Pavel Machek <pavel@denx.de>
Cc: Chin Liang See <clsee@altera.com>
CC: Pavel Machek <pavel@denx.de>
v2:
- Add Reviewed-by: Pavel Machek
- Cc: Tom Rini
Add minimal support for the MIPS Malta CoreLV board
emulated by Qemu. The only supported peripherial is
the UART.
This is enough to boot U-Boot to the command prompt
both in little and big endian mode.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC.
It boots from SPI-Flash but can be configured to boot from SD-card for
factory programming and testing.
On board peripherals include:
- 2x GbE
- Lattice ECP3 FPGA connected via PCIe
- mSATA RAID1
- USB host
- DisplayPort video output
- Atmel TPM
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
Signed-off-by: Andy Fleming <afleming@freescale.com>
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were
licensed under the GPL v3 or later, and not v2 or later. As this is
incompatible with the project, revert this board support until the
responsible parties are available to re-license (if so desired) under
GPL v2.
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and
serial.
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the
support of the i.MX6DL. The config file and the board directory are renamed
to remove the reference to the MX6Q.
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
CC: Stefano Babic <sbabic@denx.de>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Add support for the Quad version of Wandboard; fix compile warning resulting
from having 2G of memory.
Signed-off-by: Tapani Utriainen <tapani@technexion.com>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This patch adds support for the Palm Treo 680 smartphone. A quick overview of
u-boot implementation on the treo 680...
The treo 680 has a Diskonchip G4 nand flash chip. This device has a 2k region
that maps to the system bus at the reset vector in a NOR-like fashion so that it
can be used as the boot device. The phone is shipped with this 2k region
configured as write-protected (can't be modified) and programmed with an initial
program loader (IPL). At power-up, this IPL loads the contents of two flash
blocks to SDRAM and jumps to it. The capacity of the two blocks is not large
enough to hold all of u-boot, so a u-boot SPL is used. To conserve flash space,
these two blocks and the necessary number of subsequent blocks are programmed
with a concatenated spl + u-boot image. That way, the IPL will also load a
portion of u-boot proper, and when the spl runs, it relocates the portion of
u-boot that the IPL has already loaded, and then resumes loading the remaining
part of u-boot before jumping to it.
The default_environment is used (CONFIG_ENV_IS_NOWHERE) because I didn't think
that having a writable environment was worth the cost of a flash block, although
adding it would be straightforward. I abuse the CONFIG_EXTRA_ENV_SETTINGS
option to specify the usbtty for the console (CONFIG_SYS_CONSOLE_IS_IN_ENV).
Support for the LCD is included, but currently it is only useful for displaying
the u-boot splash screen. But if u-boot is built without the usbtty console, it
does display the auto-boot progress nicely.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
P1023RDB Specification:
Memory subsystem:
512MB DDR3 (Fixed DDR on board)
64MB NOR flash
128MB NAND flash
Ethernet:
eTSEC2: Connected to Atheros AR8035 GETH PHY
PCIe:
Three mini-PCIe slots
USB:
I2C:
AT24C08 8K Board EEPROM (8 bit address)
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
When a T4 board boots from SRIO or PCIE, it needs to finish these processes:
1. Set all the cores in holdoff status.
2. Set the boot location to one PCIE or SRIO interface by RCW.
3. Set a specific TLB entry for the boot process.
4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
5. Set a specific TLB entry in order to fetch ucode and ENV from
master.
6. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
7. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please
refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
When a b4860qds board boots from SRIO or PCIE, it needs to finish these
processes:
master.
ucode and ENV.
BSC9131RDB supports Sysclk
-66MHz if jumper J16 is close (default state)
-100MHz if jumper J16 is open
Add targets
-BSC9131RDB_NAND_SYSCLK100 : for NAND boot at Sysclk 100MHz
-BSC9131RDB_SPIFLASH_SYSCLK100: for SPI boot at Sysclk 100MHz
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
- Add NAND boot target
- defines constants
- Add spl_minimal.c to initialise DDR
- update TLB, LAW entries as per NAND boot
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
- defines constants
- update TLB entries as per NAND boot
LP-8x4x is a programmable automation controller by ICP DAS. It is
shipped with outdated U-Boot v1.3.0
This patch adds enough supports to boot the board:
- 128M of 128M SDRAM
- 32M of 48M NOR Flash memory
- 1 of 4 Serial consoles (PXA FFUART)
- 2 of 2 Ethernet controllers (DM9000)
Signed-off-by: Sergey Yanovich <ynvich@gmail.com>
Series-to: u-boot
Series-cc: marex
The omap2420H4 was the only mainline omap24xx board. Prior to being
fixed by Jon Hunter in time for v2013.04 it had been functionally broken
for a very long time. Remove this board as there's not been interest in
it in U-Boot for quite a long time.
drivers/serial/Makefile
Add minimal support (only boot from mmc device) for the Congatec
Conga-QEVAl Evaluation Carrier Board with conga-Qmx6q (i.MX6 Quad
processor) module.
Signed-off-by: Leo Sartre <lsartre@adeneo-embedded.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
VF610TWR is a board based on Vybrid VF610 SoC.
This patch adds basic support for Vybrid VF610TWR board.
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
common/cmd_fpga.c
drivers/usb/host/ohci-at91.c
Did a 'strings u-boot-dtb-tegra.bin | less' and saw that both
board and board_name == beaver. Didn't test as I have no T30
Beaver board here.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Add Seagate GoFlex Home support
Start with dockstar configuration
define support for RTC, DATE, SATA and EXT4FS
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
This adds support for the Cortex-A15-TC2 core tile for the Versatile
Express board by ARM. This is mostly a copy of the A5 support file,
but will be extended later with A15 specific options.
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
