An entry in the main Makefile for the mx31pdk board is not
necessary, and the board is added to boards.cfg as all
other targets.
CC: Wolfgang Denk <wd@denx.de>
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/p3060: Add SoC related support for P3060 platform
powerpc/85xx: Add support for setting up RAID engine liodns on P5020
powerpc/85xx: Refactor some defines out of corenet_ds.h
fm-eth: Add ability for board code to disable a port
powerpc/mpc8548: Add workaround for erratum NMG_LBC103
powerpc/mpc8548: Add workaround for erratum NMG_DDR120
powerpc/mpc85xxcds: Fix PCI speed
powerpc/mpc8548cds: Fix booting message
powerpc/p4080: Add support for secure boot flow
powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH
powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards
powerpc/p2041rdb: remove watch dog related codes
powerpc/p2041rdb: updated description of cpld command
powerpc/p2041rdb: add more ddr frequencies support
powerpc/p2041rdb: set sysclk according to status of physical switch SW1
powerpc/p2041rdb: update cpld reset command according to CPLD 2.0
powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver
powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver
powerpc/mpc8xxx: Add DDR2 to unified DDR driver
powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps()
powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots
powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en
powerpc/85xx: Refactor P2041RDB to use common p_corenet files
powerpc/85xx: refactor common P-Series CoreNet files for FSL boards
powerpc/85xx: Enable CMD_REGINFO on corenet boards
powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries
powerpc/85xx: Fix USB protocol definitions for P1020RDB
powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM
powerpc/mpc8xxx: Move DDR RCW overriding to common code
powerpc/mpc8xxx: Extend CWL table
powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536
powerpc/85xx: Cleanup extern in corenet_ds board code
powerpc/p2041rdb: Add ethernet support on P2041RDB board
powerpc/85xx: Add networking support to P1023RDS
powerpc/hydra: Add ethernet support on P5020/P3041 DS boards
powerpc/85xx: Add FMan ethernet support to P4080DS
powerpc/85xx: Add support for FMan ethernet in Independent mode
powerpc/mpc8548cds: Cleanup mpc8548cds.c
powerpc/mp: add support for discontiguous cores
powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries
fdt: Add new fdt_create_phandle helper
fdt: Rename fdt_create_phandle to fdt_set_phandle
powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set
fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010)
powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC)
fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010)
powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M
powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB
nand: Freescale Integrated Flash Controller NAND support
powerpc/85xx: Add basic support for P1010RDB
powerpc/85xx: Add support for new P102x/P2020 RDB style boards
powerpc/85xx: relocate CCSR before creating the initial RAM area
powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros
powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0
powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
Pre u-boot Flow:
1. User loads the u-boot image in flash
2. PBL/Configuration word is used to create LAW for Flash at 0xc0000000
(Please note that ISBC expects all these addresses, images to be
validated, entry point etc within 0 - 3.5G range)
3. ISBC validates the u-boot image, and passes control to u-boot
at 0xcffffffc.
Changes in u-boot:
1. Temporarily map CONFIG_SYS_MONITOR_BASE to the 1M
CONFIG_SYS_PBI_FLASH_WINDOW in AS=1.
(The CONFIG_SYS_PBI_FLASH_WINDOW is the address map for the flash
created by PBL/configuration word within 0 - 3.5G memory range. The
u-boot image at this address has been validated by ISBC code)
2. Remove TLB entries for 0 - 3.5G created by ISBC code
3. Remove the LAW entry for the CONFIG_SYS_PBI_FLASH_WINDOW created by
PBL/configuration word after switch to AS = 1
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Kuldip Giroh <kuldip.giroh@freescale.com>
Acked-by: Wood Scott-B07421 <B07421@freescale.com>
The EST SBC8260 is over 10 years old, and the SBC8240 older than
that. With the tiny amount of RAM (by today's standards), there
really isn't anyone interested in running the latest U-boot on
these EOL products anymore.
CC: jon.diekema@smiths-aerospace.com
Add the initial support for MX25PDK booting from SD card via internal boot.
And various defines to enable NAND support and NAND spl code for the
P1010RDB platform.
Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com>
Boot methods supported: NOR Flash, SPI Flash and SDCARD
This patch adds the following basic interfaces:
DDR3, eTSEC, DUART, I2C, SD/MMC, USB, SATA, PCIe, NOR Flash, SPI Flash.
P1010RDB Overview
1Gbyte DDR3 (on board DDR)
Local Bus (IFC):
32Mbyte 16bit NOR flash
32Mbyte SLC NAND Flash
64KB CPLD device(GPCM interface)
SPI Flash:
128 Mbit SPI Flash memory
SD/MMC:
connector to interface with the SD memory card
SATA:
1 internal SATA connect to 2.5. 160G SATA2 HDD
1 eSATA connector to rear panel
USB 2.0:
x1 USB 2.0 port: connected via a UTMI PHY to Mini-AB interface.
x1 USB 2.0 port: directly connected to Mini-AB interface Ethernet
eTSEC:
eTSEC1: Connected to RGMII PHY VSC8641XKO
eTSEC2: Connected to SGMII PHY VSC8221
eTSEC3: Connected to SGMII PHY VSC8221
eCAN:
Two DB-9 female connectors for Field bus interface
UART:
supports two UARTs up to 115200 bps for console
TDM:
2 FXS ports connected via an external SLIC to the TDM interface.
SLIC:
SPI SLIC
I2C:
Serial EEprom
Real time clock
256 Kbit M24256 I2C EEPROM
PCIe:
PCIe and mPCIe connectors.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@freescale.com>
Signed-off-by: York Sun <yorksun@freescale.com>
The following boards share a common design but with minor variations
between them:
P1020MSBG-PC
P1020RDB-PC
P1020UTM-PC
P1021RDB-PC
P1024RDB
P1025RDB
P2020RDB-PC
The P1020RDB-PC shares its roots in the existing P1020RDB board design,
however uses DDR3 instead of DDR2.
P2020RDB-PC differs from the P102x RDB-PC with 64-bit DDR and 100Mhz SYSCLK.
Key features on these boards include:
* DDR3
* NOR flash
* NAND flash (on RDB's only)
* SPI flash (on RDB's only)
* SDHC/MMC card slot
* VSC7385 Ethernet switch (on P1020MBG, P1020RDB, & P1021RDB)
* PCIE slot and mini-PCIE slots
As these boards use soldered DDR chips not regular DIMMs, an on-board EEPROM
is used to store SPD data. In case of absent or corrupted SPD, falling back
to timing data embedded in the source code will be used. Raw timing data is
extracted from DDR chip datasheet. Different speeds of DDR are supported
with this approach. ODT option is forced to fit this set of boards, again
because they don't have regular DIMMs.
CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS is defined as 5ms to meet
specification for writing timing.
VSC firmware Address is defined by default in config file for eTSEC1.
SD width is based off DIP switch. DIP switch is detected on the
board by reading i2c bus and setting the appropriate mux values.
Some boards have QE module in the silicon (P1021 and P1025). QE and eLBC
have pins multiplexing. QE function needs to be disabled to access Nor Flash
and CPLD. QE-UEC and QE-UART can be enabled for linux kernel by setting "qe"
in hwconfig. In addition, QE-UEC and QE-TDM also have pins multiplexing, to
enable QE-TDM for linux kernel, set "qe;tdm" in hwconfig. Syntax is as below
'setenv hwconfig qe' to enable QE UEC/UART and disable Nor-Flash/CPLD.
'setenv hwconfig 'qe;tdm'' to enalbe QE TDM and disable Nor-Flash/CPLD.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Zhao Chenhui <b26998@freescale.com>
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Tang Yuantian <b29983@freescale.com>
Signed-off-by: ramneek.mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Akhil Goyal <akhil.goyal@freescale.com>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Cc: Rolf Offermanns <rof@sysgo.de>
Cc: Thomas Elste <info@elste.org>
Cc: Alex Züpke <azu@sysgo.de>
Cc: Marius Gröger <mag@sysgo.de>
Cc: George G. Davis <gdavis@mvista.com>
Cc: Curt Brune <curt@cucy.com>
* 'master' of git://git.denx.de/u-boot-coldfire:
ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usage
ColdFire:Add mb for 5253 dram initialization
ColdFire:Define the DM9000 byteswap for M5253 board.
ColdFire:Update the env settings for several boards.
ColdFire:disable the NFS define for 52277 board.
ColdFire:Update the timer_init since it was unified.
ColdFire: Cleanup for partial linking and --gc-sections
ColdFire: Update compile flags for each CPUs
ColdFire:Fix the configuration broken for some boards.
Some typoes in Makefile and boards.cfg make the M54455 board
and M53017 board configuration broken.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Origen board is based upon S5PV310 SoC which is similiar to
S5PC210 SoC.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
Cc: Gary Jennejohn <garyj@denx.de>
Remove lpd7a400 and lpd7a404 boards.
Cc: Andrea Scian <andrea.scian@dave-tech.it>
Cc: Rowel Atienza <rowel@diwalabs.com>
CONFIG_ARCH_VERSATILE_PB is defined twice - drop
the define from config.h.
This deletes the integrator split_by_variant.sh script and
defines a number of unique board types for the core modules
that are meaningful to support for the Integrator AP/CP, i.e.
the ones that did not just say "unsupported core module" in
split_by_variant.sh. If more core modules need to be supported
they are easy to add.
We delete all the old cruft in Makefile and MAKEALL that was
working around the old way of building boards. We create a
unique config file per board to satisfy the build system, but
they are just oneliners that include the existing
integratorap.h and integratorcp.h configs.
Based on earlier work by Alex Waterman <awaterman@dawning.com>.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
changed at91_serial_hw_init to at91_seriald_hw_init
Cc: Albin Tonnerre <tonnerrealbin@gmail.com>
CC: Gregory Hermant <gregory.hermant@calao-systems.com>
Cc: Gregory Hermant <gregory.hermant@calao-systems.com>
Removed SBC35 from MAKEALL
